Results 1 to 9 of 9
Thread: Beams - gearbox combinations
    Member chacheen's Avatar
    Sep 2009
    charlie
    nsw
    narrawallee
    Default Beams - gearbox combinations
    which is the best gearbox to fit with a beams engine. also who is sydney is the best guy to modify engine to get big torque for a gravel rally car.
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Y not the stock one? Just a random thought.
    Mt Macedon
    Define "best".
    The options are:
    - J160, the Altezza 6 speed. Apparently the same general box used in the MX5 and RX8. This might give you options for different factory ratios, shifter positions, etc. I don't know any more, but the info must be out there.
    - W5*, Celica/Supra 5 speed. Cheaper and easier to find. You can get aftermarket gearsets for them if you want stronger/close ratio.
    - T50, not a serious option but there were a few cars that came with a T50 behind an S series motor.
    - Hollinger/Modena/whatever. Bring your chequebook.
  • #4
    Veteran AJPS's Avatar
    Lonsdale
    yager performance for the engine mods
  • #5
    Wheel Whore JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    I'd say it would be easiest to try a Stock 6 Speed first up - No mucking around with bellhousings e.t.c. - Most Altezza half cuts come with a box and everything so it would be worth trying first
  • #6
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Quote Originally Posted by AJPS View Post
    if you can ever get hold of him
  • #7
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    and if he doesn't think what you want is beneath him
  • #8
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    What car is the beams going into?
    personally i would go w58 so you can still have a good shifter position and w58's have proven them selves to be a strong box
    Just another Muppet
  • #9
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    I've got two bellhousings for sale you might be interested in? they let you mount a w-series gearbox to 3sge engine without any mod's
    ADM AE86 Levin
  • Similar Threads
    1. Replies: 9
      Last Post: 28th May 2013, 02:40 PM
    2. Replies: 9
      Last Post: 17th March 2013, 09:47 PM
    3. Replies: 1
      Last Post: 3rd February 2013, 10:50 AM
    4. Replies: 5
      Last Post: 25th January 2013, 05:25 PM
    5. [BRIS] J160 (IS200/beams) gearbox. No shifter. Cheap!
      By 70XIN in forum Car Parts For Sale
      Last Post: 24th September 2012, 03:22 PM
