AE71 4AGE COILS 2WAY TRD
Engine and gearbox:
4age bigport
twin 40mm solex carbs
TRD Camshafts, Degreed in
TRD undershim buckets
TRD Valves
TRD Valve spring
TRD adjustable timing gears
TRD bottom end
Aftermarket ignition system- due to the carbs
silicon leads and new spark plugs
2.5 inch exhaust
twin exit muffler
lightend flywheel
new clutch, havnt done 100kms on it yet
ARP flywheel studs
DIFF:
Celica rear end
TRD 2way lsd
Ksport adjustable link
Ksport Top and bottom control arms with rose joints
Suspension:
Ksport front coil overs, ae86 model fully adjustable
AE86 P/S steering arms
RCA's
JDM AE86 callipers with slotted rotors
JDM Rack
Custom Braided brake lines
ksport Rear coil overs, fully adjustable
Ksport control arms, fully adjustable
standard brakes
15X7 superlights with nexen rears and toyo fronts, slight fitment
Body and interior
Two fixed back buckets
aftermarket steering wheel
dash mat and chrissy tree
ZERO Sound system, nothing, nada. the engine sounds to good
The body is in good condition, it could do with a clean up. Panels are straight except from a few spots on the front.
Zero rust on the chassis and sill. on small spot on the rear, and some key scratches from some $*&%%$*^%@$($#^##*&^%$@ Heads
tidy on the inside, i had planned to strip the interior but wanted more of a streeter than track car
Ive built this car up over the last year. its the second ae71 ive owned. everything good about my last car is in this. i dont drive this very often, as i have a work car to drive
and another daily. But i absolutely love being behind the wheel of this car. it handles, sounds and goes like a toyota should. Never seen a defect sticker, 100 clean.
the only issues are that its a bit loud to drive, with the solid links and 2 way, and its not a Quad light jdm version.
Has 3 months walk in rego, full set of ae71 csx rims plus some other bits and pieces from the efi system.
Price: $7300.
NO SWAPS!NO SCAMS!NO LOWBALLERS!
serious interest only. located in adelaide. email js_84@live.com
https://www.dropbox.com/s/hdldnz2mfkgydw4/P1000541.JPG
https://www.dropbox.com/s/m1nu8n7dmd39gp5/P1000542.JPG
https://www.dropbox.com/s/lprh4li5ynqbdwi/P1000543.jpg
https://www.dropbox.com/s/i4mygpns1s69f1a/P1000544.JPG
https://www.dropbox.com/s/9m84ca1ukps47mz/P1000545.JPG
https://www.dropbox.com/s/92pr3se37bl3kpe/P1000546.JPG
https://www.dropbox.com/s/l16qknot6a459xf/P1000547.JPG
https://www.dropbox.com/s/g211ehu8igzyl2p/P1000550.JPG
https://www.dropbox.com/s/61iwx3w0k869how/P1000551.JPG
https://www.dropbox.com/s/7dmhk6799xtw1so/P1000552.JPG
https://www.dropbox.com/s/mcuyucfwmo4m0qb/P1000553.jpg
https://www.dropbox.com/s/g1bp16mjwh4781k/P1000554.jpg
https://www.dropbox.com/s/29ei2gpghgc7nl4/P1000555.JPG
https://www.dropbox.com/s/4tr9kbwmc0uer8o/P1000549.JPG
https://www.dropbox.com/s/xjhj716vyz0zdd5/P1000548.JPG
