Results 1 to 10 of 13
Thread: Help please ae86 20v not running right
    Jun 2012
    lui
    nsw
    summer hill
    Default Help please ae86 20v not running right
    I purchased a 20v setup for my ae86 from someone off this forum i recently got it running and car is not running right for one issue is the alternator wire heats up really hot and smokes up and i changed alternator same problem also car when i try too drive it when accelerate too much the car doesnt wanna go anymore there a two plugs i found on harness that not connected i spoke too the previous owner of the engine apparently he gave me all the wiring its running an ems ecu can anyone help me out or recommend someone too bring the car too thats located in sydney thanksClick image for larger version.
ID:	28385Click image for larger version.
    Should be fairly easy to resolve... Are you referring to the thick alternator wiring? Usually heat is a result of too much current in that the wires are too thin or poor connections.
    If you don't have 14v across your batt terminals when running, the car will run like arse too... Unless the dead times have been setup correctly.
    This package didn't come out of a gold sprinter did it? Reminds me of drews setup
    Jun 2012
    lui
    nsw
    summer hill
    Yeah it did come out of drews old car did he have issues
  • #4
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the alternator is not independent in wiring to the ECU so any auto elect should be able to help you here
  • #5
    looking at your picture those 2 white wires, they should be connected to the battery (most likely) and that would be the reason why your alternator is over heating, it would be charging through the sense wire which doesn't have the amperage...
    Not unless they are left overs from when the 4ac was in there... and take a pic of the alternator side and post it up.
    Do you own a multi meter?
  • #6
    Sep 2012
    Tristan
    Koongal
    its always a good idea with these older engines to run new power wire from the alternator to the battery - i use 4 gauge wire and a fuse just after the battery ( you can get defected for no fuse!!)
    and also run new engine and chassis earths
    check your resistences and voltage drops kinda sounds like a dodgey/bad connection somewhere
  • #7
    Jun 2012
    lui
    nsw
    summer hill
    Quote Originally Posted by Matt View Post
    Yeah matt we did connect the white wire same problem that wiring was from the 4ac yeah my mate has a multi meter i forgot now how much it was charging
  • #8
    Jun 2012
    lui
    nsw
    summer hill
    Quote Originally Posted by Twisty92 View Post
    Thanks mate we were planning too test it with a new wire today going too give that a go and let use know how we go
  • #9
    Jun 2012
    lui
    nsw
    summer hill
    His some pics of the alternator wiring
  • #10
    Mar 2011
    Ali
    So this was 4AC before conversion....Have you taken the voltage regulator out of the equation?
    Uploaded with ImageShack.us
    Looking at this 2nd pic suggests voltage reg has been deleted, just cut out and wires taped, or is that the stock wiring from the 4AC ALT?
    Either way I would strip the loom on charge wires and see what is going on and clean it up.
    Does the ALT lamp work properly on dash?
    Is that the alt charge wire coming across the front of the motor to ANL fuse?
  • Page 1 of 2 1 2 LastLast
    1. 4age 20v not running
      By Twisty92 in forum Technical - Questions
      Last Post: 27th March 2013, 08:46 PM
    2. 20V ae86 running horrible problems
      By drift kid in forum Technical - Questions
      Last Post: 10th September 2012, 09:30 AM
    3. Blacktop 20V running on 2 cylinders
      By Adsie in forum Technical - Questions
      Last Post: 6th December 2010, 10:31 PM
    4. ae86 rolling shell, silvertop 20v rwd setup running and tuned
      By mulligan in forum Car Parts For Sale
      Last Post: 21st November 2010, 09:20 PM
    5. Running coils on a 20v
      By DRF786 in forum Technical - Questions
      Last Post: 11th October 2006, 07:24 PM
