Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 30 of 52
Thread: AE86 rims what off set will i need?
  1. #21
    Member Dskew3's Avatar
    Feb 2013
    dustin
    Palmwoods
    Yea jdm wheels that sounds pretty good cause ae teks where gonna cost about the same when it comes time to get rims ill give ta a yell cheers mate. I gotta get an exhaust first
  2. #22
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    i second jacobs yarn. 15x8 0 offest. ive got that on my ae86 with standard gaurds. i folded the inner lip in recently then put spacers on for them so it would sit properly so that gives you an idea of the clearance
  3. #23
    Aug 2012
    jason
    qld
    ipswich
    I bought rota grid classics 15x7 0 offset for 750 new and put some 195 50 15 federal rsrs new for 440. Ive been down the second hand route before and unless you could have the runnout and checked for buckles before purchase its a gamble as i found out. not everyone can afford new watanabes. Oh and 15x8 -0 will stick out up front as i found test fitting with king spring lows and 3degrees neg camber and 205 50 15 tyre. rear was perfect flush so that why i went with 7s.
  4. #24
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    those AE TEK wheels look fucking horrendous.
  5. #25
    Sep 2010
    Craig
    Perth hills
    Jason: I've got 195's on my 15x8 0offset grid V and they are still well within the gaurd on the front. And those gaurds haven't been pulled or anything. I only lipped them so I could run it with spacers and super low with max castor wound in. I'm a lil unsure as to how you got 3 deg camber without a longer control arm hence making your wheel sit further out to start with. I'm running cusco tops at max camber and only get around 2 deg. Plus 205 tyres means they will deffs stick out.
  6. #26
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    15x8 0 offset wheels with 195/50 tyres sit perfectly on 86's. As everyone has said!
  7. #27
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Even 205/50/15 on 15x8 zero offset fits fine on an 86, 195 would have loads of space.
  8. #28
    Aug 2012
    jason
    qld
    ipswich
    Spose the real question is what is the cars intended use. if its for grip no point running a 195 50 15 stretched on an 8 inch rim with zero offset which will change your scrub radius and destroy the cars handling and produce zero grip. if its for stance or drift then no issues. Best just go to the wheel supplier and have wheels test fitted as everyone has different views on the subject. good luck with your selection.
  9. #29
    Feb 2013
    dustin
    Palmwoods
    I was hoping for going with drift/togue I want practical no impractical
  10. #30
    Veteran AJPS's Avatar
    Lonsdale
    195/50 'stretched' on an 8 inch rim produces zero grip and destroys the cars handling is quite a big call
  1. Replies: 1
    Last Post: 1st August 2011, 04:36 PM
  2. Replies: 17
    Last Post: 23rd May 2009, 01:27 PM
  3. Full Set of Rims
    By GOODY in forum Car Parts For Sale
    Last Post: 22nd March 2009, 01:11 PM
  4. some 13x7 rims set 4
    By wide s13 in forum Car Parts For Sale
    Last Post: 15th March 2008, 05:21 PM
  5. F/S: Set of Standard Rims
    By Project_dorifto in forum Car Parts For Sale
    Last Post: 15th October 2007, 07:18 PM
