Results 1 to 2 of 2
Thread: Thread size & pitch wheel bolts rear axle toyota crown MS112
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Default Thread size & pitch wheel bolts rear axle toyota crown MS112
    Car - AE86 with Toyota Crown MS112 rear axle
    motor / part in question - Wheel bolts rear axle
    I'm looking for the thread size and pitch of the rear wheel bolts/studs on a Toyota Crown MS112 (disc brake version). So far I found M12x1.5 but can anyone confirm this?
    Thanks in advance!
    ADM AE86 Levin
    Mt Macedon
    Yes, they're M12x1.5, just like most (all???) Toyotas of that vintage.
    I discovered that 1/2" 16tpi nuts will kind of work, but is dodgy as all fark.
  • Similar Threads
    1. WTD: MS112 Crown diff centre
      By AE86 Spoontah in forum Cars or Parts Wanted
      Last Post: 13th June 2012, 03:42 PM
    2. Coolant temp sensor thread size and pitch
      By slide86 in forum Technical - Questions
      Last Post: 1st June 2011, 09:03 PM
    3. T series diff centre to crown wheel number of bolts
      By ae86 in forum Technical - Questions
      Last Post: 30th July 2009, 05:58 PM
    4. T series crown wheel bolts
      By 483NDS in forum Cars or Parts Wanted
      Last Post: 13th May 2009, 05:07 PM
    5. 4x114.3 25mm bolt on spacers toyota thread pitch
      By slydar in forum Cars or Parts Wanted
      Last Post: 16th June 2008, 04:33 PM
