Results 1 to 10 of 12
Thread: 4age Vacum Line help!
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Default 4age Vacum Line help!
    Car - AE86
    motor / part in question - Vacuum Line
    problem - Car starts then dies.
    occurs/started when (if applicable)- Just today-after replacing head gasket
    personal situation (if applicable)- Finally got my ae86 to start but it wont idle and the pic below shows were Im sure the vaccum leak is coming.
    Zoomed
    The line going down^^
    Thanks in advance
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    I mean the thin vacuum line btw.
    Aug 2010
    Geoff
    mt dandenong
    Map sensor hooked up?
  • #4
    Elite rthy's Avatar
    Leo
    Tulla
    bigport 4age?
  • #5
    Veteran Nikkojoe's Avatar
    Tom
    It's a 4age in North America and all are AFM.
    Most guys on these forums wont have any idea of what vac lines you are supposed to have hooked up because our 4age engines dont have them (we have pretty much 3 in total - 1 to FPR, 1 to map sensor and 1 to charcol canister).
  • #6
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Quote Originally Posted by Nikkojoe View Post
    Forgot about that, shoot.
    Thanks for the replies
    Here's a video of what it does, if you have any other suggestions other than vacuum that'd be appreciated.
    http://www.youtube.com/watch?v=V3ubAV5O5ug
  • #7
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    If that's a vacuum leak, it's a big one. Is the booster hooked up?
    bursting ovaries since 92'
  • #8
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Quote Originally Posted by blake. View Post
    What booster?
    I'll admit I dont know much about the 4age. Please explain?
  • #9
    Jun 2009
    Blake
    Penrith
    the big vacuum hose (internal diameter of about 5mm) the goes frome the manifold the big black thing the the brake master cylinder bolts to.
  • #10
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Yea its connected, you can see it in the first picture too.
    One last thing is must this be connected:
    Female connector is stuck onto it and wire broke..
  • Page 1 of 2 1 2 LastLast
    1. Smallport - vacum leak.
      By Smitty in forum Technical - Questions
      Last Post: 13th December 2009, 08:03 PM
    2. Turbo oil line/water line
      By Stej in forum Technical - Questions
      Last Post: 22nd November 2009, 12:14 PM
    3. ae86 4age fuel line
      By evil86 in forum Technical - Questions
      Last Post: 9th September 2009, 08:33 PM
    4. WTB BT Map/Vacum Sensor
      By 4.5AG in forum Cars or Parts Wanted
      Last Post: 16th January 2009, 11:17 PM
    5. where to put vacum line for brake booster
      By n00bvak in forum Technical - Questions
      Last Post: 5th May 2006, 07:02 PM
