Hay guys selling my ke70 sr20det car has been running complete for about 6 months down a couple track days an the car drive an handles great plenty of power an just lights tires real easy.
Quick list of what's its got down off the top of my head:
quad headlight front end
tubed radiator support ( removable for easy engine access )
sr20det motor came from a mates smashed mint s15, I no we have all herd the motor had low Kim's bullshit but this car was actually mint very low Kim's I think around 120kms but ant be 100%.
s14 5 speed with heavy duty clutch.
Resest firewall for back of motor an dump pipe.
resprayed engine bay.
25mm extended LCAS
ae86 struts with PBM coil overs mounted an allnae86 brakes up front.
2x bride low max fix backs.
4point harness
4point cage.
nardi wheel.
pbm hydro with separate canister
auto metre gauges (need fittings installed in motor an box for all)
New carpet painted
black dash
new front sscreen rear firewall welded with steel panel.
Flat boot floor with big alloy fuel cell carter black pump for lift, Bosch 040 for feed, 2litre surge tank.
Early Hilux diff 31 spline axels welded centre r31 slotted discs, vs commodore brake clippers, and willwood twin piston hydro calipers, steel braided hydro lines
3" steel exhaust with 2&1/8" twins from diff back. Sounds great!
Wheels are 14x9 -25 ssr mk3's an 14x8 -17 reverse mesh
hand made steal rear guards made from 8mm steel solid wire bar, an shaped steel sheet, delam will never destroy.
Dono what I have missed so any questions txt me as I'm not on here to often an cant answer calls to often.
I can't upload pics so txt me for them.
asking price is $10,500 Ono.
Could possible consider swaps or swaps + cash.
Located in Sydney NSW, Liverpool
HIT AND RUN!
I miss those mk3's!! Nice looking setup mate!
Thanks mate, if I have to part the car out ill let you no for those rims
HIT AND RUN!
Will consider swaps + cash my way, must be something registered, some kind of ute would be ideal, but open to what you got?
cheers
HIT AND RUN!
free bump, would be interested in a few things if you end up parting.
Thank mate, what may you be interested in??
HIT AND RUN!
Can I ask about the different colour front, was there a bingle or just the swap to the quad lights?
diff and cage
