Results 1 to 6 of 6
Thread: 4AGE 16v TVIS Solenoid and Idle Control Valve.
    Senior Member Mika's Avatar
    Jun 2011
    Daniel
    Default 4AGE 16v TVIS Solenoid and Idle Control Valve.
    Hey lads,
    Wasn't too sure on where to put this thread. I have just done a 4AGE 16v conversion to my KE. The last 2 things that are on my list are 2 vacuum leaks coming from the TVIS Solenoid and Idle Control Valve. Anyone have any trouble with these in the past? Worth fixing? Can be fixed? If not, anyone know where the best place to get these parts from would be awesome!
    Cheers,
    Daniel.
    Junior Member Damon550's Avatar
    Jun 2009
    Damon
    Beauty Point
    i made a thick full gasket for the idle up system to eliminate it
    Jun 2011
    Daniel
    Cheer mate, will try that.
  • #4
    Veteran Nikkojoe's Avatar
    Tom
    Just check and make sure you have coolant flowing to the cold start idle up under the throttle body (these can get blocked up over time). Good thing to do is take it off and clean out all the gunk in the air ports if you haven't already done so using some throttle body cleaner then spray wd40 in there to make the valve move smoothly as the temperature increases.
  • #5
    Member rianwest's Avatar
    May 2010
    Rian
    Taringa
    Early 3SGE engines also used TVIS. I replaced my broken 4AGE TVIS solenoid with a 3SGE one not too long ago.
    Also with the idle-up/cold start thing, I ditched it like most people do and just replaced it with a blanking plate and a gasket like this:
    http://www.rollaclub.com/board/index...tach_id=100833
  • #6
    Tom
    I think i'm the only one that still runs one.... even on my 4agte
    I guess other people like their idle above 1k or like trying to keep their foot on the gas when cold
  • Similar Threads
    1. Replies: 11
      Last Post: 12th February 2012, 03:57 PM
    2. TVIS Control solenoid to suit a 4age 16v
      By dirk in forum Cars or Parts Wanted
      Last Post: 12th September 2009, 04:47 PM
    3. WTB: aw11 gze idle control valve
      By mistr2 in forum Cars or Parts Wanted
      Last Post: 22nd January 2009, 06:54 PM
    4. 4age idle control motor
      By lewy in forum Cars or Parts Wanted
      Last Post: 11th March 2007, 08:37 PM
