Cheers matey
Had to figure out where a clunking/knocking/rotational sound was coming from, thought it was the tail shaft bottoming out on the tunnel. Turns out I believe it's a slight nick on the pinion gear, kinda knew this before install, though thought would of been alright. Possibly might be able to grind/sand smooth, though won't take the chance. Looking for a center with 3.91's otherwise its $500 to my good friend Con (lol) from Diff Technics.
Bought the SR wing.
Removed front guards, cleaned up, prepped and sprayed, same with front of car, air condenser etc. Bought and fitted new front lights and Indicators.
Have bought a new pair of front guards, along with the bonnet and boot lid SR which are all getting the prep work done.
Things on order:
Ac Belt
Ac Bearing - Rebuilding AC compressor
Hydro
Ma61 front wheel bearings
Turbo beanie
4 Inch holesaw
4 Inch Silicon (for CAI for TMIC)
Front main oil seal
Need to get:
All fluids + sparkies (car runs but might as well)
Tyres - $250 set for cheapies
Hose clamps - meh
Brakes lines for Hydro
Things needed to be done:
Remove diff center and repair
Remove front coil over - Binded up - simple fix
Fit hydro
Fit ma61's
Fix front main oil seal leak
Remount Ac
Possibly digital oil pressure gauge
Re wire battery cable front to back
Make CAI for TMIC and section off TMIC
Full service
At this stage, the car should be sway. Will just need a wheel alignment and then its rego.
1st thing once rego'd, will be to go get the ignition timing done, remove AFM, install new sensor AFM, custom pod box, refined tune (now running 11.0 AFR on +100% fuel load so its a very safe tune atm) should be good for 150rwkw sub 10psi.
After this, engineer and drive.
Will have some time then to get the car resprayed, and then the rest of the shit tricked out like
Suspension
Solid mounted bushes for diff with adjustable links
Front bushes
Sway bars
Rear shockies + springs (or coil over/type)
Power steering arms
New LCA's xt130
Not sure about hubs
Slotted and vented discs (easily just replace with solid old ones)
And do something with the wheels - 15x8.5 all round most likely
It will be a random next couple of months, just can't wait to drive and appreciate the car on the road. It should be well setup, as well as a daily
Mick
