Results 1 to 7 of 7
Thread: 4AGE Oil System
    Jan 2013
    Glenn
    Carrum Downs
    Default 4AGE Oil System
    Hi all, I know this is going to be a stupid question for all you guys in the know, but I'll ask it anyway. Where does the tube that comes out from the oil filter housing attach to? It would seem perfect for an oil cooler but don't know where to plumb it back to. The motor was a FWD converted to RWD. The car is being built as a track car and is coming along slowly. The rear end is out for building at the moment 4.11 mini spool borg warner out of a pintara. Regards, Glenn
    FWD cars have oil coolers.... grab one off an ae82 and use that or buy one.
    Or replace the oil plate thingy with a 16v / 20v one without the cooler.
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    Whats the deal if i go aftermarket? Mine just has that tube plumbed back into the sump, can i just throw a sammich plate on as per usual?
  • #4
    Senior Member dangdang's Avatar
    Aug 2010
    Danga
    Tas
    Aus
    The factory fwd samwich plate has a pressure valve within that diverts oil to the cooler once a certain pressure ie rpm is reached.
    You could run it either with the very basic factory cooler or an aftrmarket cooler core but
    Much better to get rid of it and run a proper thermostatic plate that will achieve full flow once oil is to temp and a decent cooler core.
  • #5
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    i have a standard fwd one on my 20v
    just put an oil cooler after it then as said plub it back to sump
  • #6
    Jan 2013
    Glenn
    Carrum Downs
    Quote Originally Posted by cooter View Post
    Thanks for the reply's guys. If I go the other way and decide not to use an oil cooler, can I just block this tube off?
  • #7
    Elite rthy's Avatar
    Leo
    Tulla
    ill assume ur talking about the sandwich plate plate?
    there is a return located on the sump, can just drill a hole and put a nipple for the oil to return too.
    Otherwise u can remove the sandwich plate, but if ur ganna be thrashing the motor might as well keep the oil cooler
    Ie. http://i1176.photobucket.com/albums/...g?t=1331972242
  • Similar Threads
    1. 4A-GE oil system
      By Group A in forum Technical - Questions
      Last Post: 21st June 2010, 05:38 AM
    2. 4age engine oil / T50 gearbox oil
      By pogi in forum Technical - Questions
      Last Post: 27th May 2009, 11:27 PM
    3. 4age oil system.
      By BJT27 in forum Technical - Questions
      Last Post: 29th April 2009, 05:36 PM
    4. 4age OEM Oil Cooler System/Setup for $80
      By thanhngo in forum Car Parts For Sale
      Last Post: 21st August 2007, 10:46 PM
