Results 1 to 8 of 8
Thread: Smallport 16V 4AGE Head Questions
    Jan 2011
    Hayden
    Tapping
    Default Smallport 16V 4AGE Head Questions
    Hey Guys,
    I've got a couple questions regarding a smallport 16v complete cylinder head that i've been given by a friend.
    A little bit of background info on the head and my car,
    Engine was a 4age 16v smallport from an ae93 gti.
    The engine was swapped due to a cracked block, my friend claims the new motor never went as well as the old one.
    He seems to think the old motor may of had aftermarket/larger cams fitted due the way it rev'd/went after 3000 rpm.
    I have an early 4age 16v bigport 16v in my ae71.
    Question 1: Is there anyway visually or measuring to comfirm if the cams have been changed ?
    Question 2: If the cams have been changed is it possible for them to be fitted into an early 4age 16v bigport head ?
    Question 3: Will you need to swap all the shims and bucks over aswell ?
    I know that you can fit bigport cams into a smallport head, but i couldn't find any info if you could do the opposite.
    I'm guessing that you could do it.
    Thanks Hayden.
    Mt Macedon
    1: Get a set of calipers and measure. Across the smallest part of the lobe gives you the base circle. From the tip of the lobe to the far side gives you the max height. The difference between these two is lift. There may also be markings on the cams you can Google.
    2: Yes.
    3: Once the new cams are fitted check your valve clearance and adjust to suit. If you have two sets of shims you'll probably find you can swap them around to make it work, but in any case you can't avoid measuring.
    4: Yes, you can swap the entire smallport head onto your bigport for even more sikness.
    Jan 2011
    Hayden
    Tapping
    Thanks hen for your reply, very helpful info.
  • #4
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Quote Originally Posted by Hen may possibly be a nut View Post
    Well, you can't. You can swap the internals over, but the actual head itself is different, so if you put the the small port head on your inlet manifold will not fit!
    Will
    SuperFunHappySliders
    SR's are ghey.
  • #5
    Mt Macedon
    Well, you can.
    True, it's not plug and play, but you sure can bolt a smallport head on. Intake adaptor or cut'n'shut smallport intake required, also smallport fuel rail, plus other odds and ends. No big deal.
  • #6
    Mar 2011
    Ali
    Off topic but is the Smallport GZE and NA fuel rail one and the same?
  • #7
    Mt Macedon
    I think they are the same, but if not they are interchangeable. I've used a smallport GZE fuel rail on an smallport NA manifold.
  • #8
    Mar 2011
    Ali
    Exactly what I'm about to attempt.
    Thanks Hen.
  • Similar Threads
    1. WTB: 16v Smallport Head
      By s3phro in forum Car Parts For Sale
      Last Post: 5th July 2011, 11:22 PM
    2. Replies: 7
      Last Post: 2nd September 2010, 04:17 AM
    3. WTB: 16v Smallport Head complete
      By kerola in forum Cars or Parts Wanted
      Last Post: 8th August 2010, 02:41 PM
    4. 4a 16v smallport head w/RWD manifold
      By sundee in forum Car Parts For Sale
      Last Post: 11th April 2009, 12:00 PM
    5. 100kw smallport head on JDM RWD 16v
      By DRFT - 86 in forum Technical - Questions
      Last Post: 23rd March 2008, 02:21 PM
