Results 1 to 10 of 10
Thread: WTB Uprated cam springs, high comp pistons
    Senior Member MoNsTaR's Avatar
    Jul 2009
    Richmond
    Default WTB Uprated cam springs, high comp pistons
    hey guys,
    Im in need of a set of cam springs that can handle 11mm lift.
    and i need some high comp pistons, 11:1 and up.
    thankyou
    Quote Originally Posted by sam2306 View Post
    its not a gang till we have stickers
    Quote Originally Posted by *E7* View Post
    rust is lighter than carbon fibre
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I can supply you with Supertech springs, I will send you a PM
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Pistons to suit 16v or 20v, and what pin size?
  • #4
    Jul 2009
    Richmond
    16v pin size doesnt matter as id most likely be getting rods soon,
  • #5
    Veteran stahlz_ae86's Avatar
    Paul
    What motor do you have? Knowing what motor will mean you're restricted to rods that suit it's crank therefore pistons to suit those rods...
    If you buy the wrong pistons first, then buy the rods to suit those pistons you will need to change your crank.
  • #6
    Jul 2009
    Richmond
    understood, id prefer 18mm pin size because i have cleaned all my bigport parts but i have a couple of cranks to choose from, which is why im not too fussed.
  • #7
    Jul 2009
    Richmond
    bump, let me know what you have or if anyone can source some pistons
  • #8
    Paul
    Maybe try Precision international in Brisbane I was lucky enough to be working near there a couple weeks ago and got my smallport pistons there, try give them a call and see if they have high comp on the shelf...
    Well priced, I payed about 200 for 1mm oversize endurotec pistons with chrome rings (Hastings).
  • #9
    Gone
    Joel
    Picton
    James PM me if your still looking.
  • #10
    Jul 2009
    Richmond
    no longer looking thankyou everyone for your help!!!!
  • Similar Threads
    1. 4AGE hi-comp pistons
      By tc-rolla in forum Technical - Questions
      Last Post: 19th November 2012, 10:26 AM
    2. High Comp small port pistons with ae111 head on 7a block?
      By Grant #2 in forum Technical - Questions
      Last Post: 5th May 2012, 11:12 AM
    3. beams pistons in 2 comp ratios
      By Celica RA45 in forum Technical - Questions
      Last Post: 20th December 2010, 03:38 PM
    4. R34 GTV Sydney - High comp, Haltech, etc etc)
      By wideslider in forum Cars for Sale (Not Toyotas)
      Last Post: 23rd September 2010, 06:20 PM
    5. high comp headgasket on gze
      By dustyae86 in forum Technical - Questions
      Last Post: 17th July 2007, 02:33 PM
