Results 1 to 10 of 16
Thread: Point in a 7age?
    Member High-Rolla's Avatar
    Feb 2013
    Nathan
    Cool Point in a 7age?
    hey guys im not really sure.... this is kind of a noob question, Buuuuut! whats the point in putting a 4age head on a 7afe block? why not just keep the 7afe head? is the 4age head better? i have no idea how because both heads have 4 valves to a cyl both are DOHC? whats the point? (: thannnnnks.
    Interesting question...
    4age - has always been considered the performance head, free high reving motor
    4afe - economy head which doesn't flow as well.
    I wonder how a high comp 4afe would run
    Feb 2013
    Nathan
    Where could you get a 7afe? Are they easy to come by?
  • #4
    Elite rthy's Avatar
    Leo
    Tulla
    have seen some american vids of modded 4afe's vs 4age's... and the economy head wons
    7afe's are all over the place, AE101's, AE92 RV's etc..
  • #5
    Aug 2010
    Adrian
    South
    Also because a 4age head is alot easier to run in rwd format compared to 7afe
  • #6
    Even in fwd form, most still do the AGE head...
  • #7
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I've been told by several people who have done the development that the 7afe head has a lot more potential than any of the 4age heads do. Just you can use the ge head and just bolt on water fittings to be rwd, instead of having the design and make stuff up to get it to work. And everyone says the ge head is the better one, so everyone just follows that idea...
  • #8
    Mt Macedon
    I can remember a similar discussion years ago where Bill Sherwood espoused the view that a particular generation 4AFE has the head with the most potential.
    My understanding of the situation:
    - GE head is better out of the box and has heaps of aftermarket support
    - FE head (well some of them) have a better fundamental design (angle of port toward valve, etc) so will end up better if you go all out. But given the lack of aftermarket you'll be looking af lots of custom stuff.
    However I have no real data or experience to back it up.
  • #9
    Moderator Sam-Q's Avatar
    Endeavour Hills
    As above, I was going to make a high performance FE head but my idea shut down shortly after Kelford cams in QLD did because no one could sell me some rewelded cams for much less than $1000.
    People fit the 7afe bottom end to a 4age because firstly their readily available and good later model 4age cranks are not- well second hand anyway. Then they are also meant to shift the max power being generated so it happens about 1000rpm sooner, so more driveable
  • #10
    Would 4age cams drop into a 4afe head with the right prep? or are they totally different setups?
  • Page 1 of 2 1 2 LastLast
    1. Replies: 22
      Last Post: 5th March 2012, 10:33 AM
    2. 7age pistons
      By jimmy19650 in forum Technical - Questions
      Last Post: 31st December 2009, 10:56 PM
    3. monza 4 point racing harnessgot a monza 4 point harness
      By HiLtOn in forum Car Parts For Sale
      Last Post: 29th September 2007, 02:35 PM
    4. 7AGE
      By juzzo84 in forum Technical - Questions
      Last Post: 27th December 2006, 09:17 AM
    Tags for this Thread
