Results 1 to 7 of 7
Thread: 4age crank - smaller lighter or larger heavier?
    Dec 2011
    Craig
    Granton
    Default 4age crank - smaller lighter or larger heavier?
    I’m in the process of planning and collecting parts for a replacement engine for my AE86 rally car and I’m undecided about which way to go in relation to the bottom end.
    I have to run a bigport head, but the regulations for the bottom end is basically free of restrictions other than me wanting to stay under 1600cc.
    Do I go for the later larger heavier bottom end or the earlier smaller lighter bottom end?
    I want a strong engine that will run between 4000-7500rpm all day in competition that will result in about a ~11.3:1 compression ratio. I’m not chasing sheep stations, so I’m not going to buy really expensive brand new parts, when I can make do with a cheaper alternative. But I want to make the right choices and not just go with the general opinion of the internet, which appears to be the larger later model bottom end, without real justification.
    So, to quote Bill “Both cranks are extremely strong, and only break with quite a bit of mis-treatment. The 40mm crank weighs about 11kg and the 42mm crank about 11.7kg.“
    I have 2 blocks, and both appear to me to be 7 rib blocks.
    Block 1 came with the car and I believe it was originally from the head that is currently in the car.
    It doesn’t have the external oil drain but it contains a visibly smaller crank with small big end journals (My research suggested that all 7 rib blocks hat 42mm big end journals but I have one with 40mm big ends.) The bores look a little rusty but I think would clean up with a hone.
    Block 2 I bought as a parts package early in the year and is a small port block. The crank has a few scratches on the big end journals but the bores look pretty decent and obviously has oil squirters.
    One of the normal reasons given for going with the later model crank is to use the matching factory 10.3:1 pistons. But I bought a set of used HKS pistons on Ebay that are supposed to be “high compression”. They suit an 81mm bore and have 18mm wrist pins but no specs other than what I can measure but they will fit up to the early model light crank/light rods.
    From left in photo above -HKS aftermarke 18mm pin, Toyota original piston 18mm pin, Toyota original 20mm pin.
    A search of HKS 4age piston for specs only finds this reference http://www.toysport.com/catalog/part...ngine/4AGE.htm
    It lists a 81.00mm 8.0:1 or a 81.25mm 11.4:1 piston so can anyone tell me some more details about what I have? I’ve measured my set and it appear to be 80.90mm which I assume is to suit 81mm, but it doesn’t look like a low compression piston. I’ve measured the height of the “dome” from above the pin and it is similar height to that of the outer ridge of the big port piston.
    Now, can anyone tell me any reason why I couldn’t use the early crank in the later small port block. What about the oil squirters? Would the HKS pistons need clearance for the squirters? Can they be modified for a decent price? If the oil squirters are removed, do the oil galleries leading to them need to be blanked off to keep oil pressure up?
    Thoughts?
    Craig
    Senior Member toyotakraze's Avatar
    Jun 2009
    Robbie
    Coorparoo
    Quote Originally Posted by rallysprinter View Post
    Thoughts?
    Craig
    I can't tell you much about the rest but if you have a chance to have/keep oil squirters then do it because the do make a differance in keeping pistons cool especially if your using higher rpm for extended periods of time
    Rob
    Who took the jam outta your doughnut?
    You took the fucking jam outta my doughnut, Tommy. You did.
    May 2012
    ACT
    belconnen
    I would go with the combination that gives you the lighter reciprocating mass.
    You could always just try assembling the engine with the bigport crankshaft / conrods / pistons. No doubt, you'd see any problems before you got very far.
    and, yeah, as Rob as said, dont remove the oil squirters for a racing engine... If nothing hits them as you're moving the rotating assembly, they're fine.
    So, how much do the HKS pistons weigh compared to the other 2 typs you have?
  • #4
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I don't know much the topic but I would think the later crank with the equal full counterbalances would be better at dealing with the higher revs. You might be interested to know that Brian Crower rods are very light and cheap delivered. If you budget is a little more I know someone selling some trd race rods that are stupidly light
  • #5
    Dec 2011
    Craig
    Granton
    Thanks Guys,
    Decided to go with the heavier smallport crank so I could easily stick with the oil squirters. I already have some spool rods to suit and I'll get some hypatec pistons.
    I've onsold the HKS pistons but didn't have scales to weigh them sorry SamsTA22.
    Craig
  • #6
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    If you're looking at hypatec pistons in particular I can get them really cheap through work. Pm me and i'll see what kind of pricing I can do for you. I would use a modified smallport crank, plenty of weight can be taken out easily enough to match and better the weight of the 40mm crank.
  • #7
    Dec 2011
    Craig
    Granton
    Quote Originally Posted by Jimmee1990 View Post
    Thanks James, I'm not set on hypatec pistons, but I'm just after a good set of standard bore pistons for a NA engine at a reasonable price. I was originally just going to buy genuine toyota but they are not available anymore, but I came across those hypatec pistons on the precision website and a quick internet search suggested they'd do the job for me and it seems the price is quite good.
    I'll PM you in a couple of weeks about a price.
    Is there any knowledge on the interweb I can hand onto the machinist about taking weight out of smallport crank?
    Craig
  • Similar Threads
    1. Larger Alternator Pulley to Suit 4AGE
      By archie1 in forum Cars or Parts Wanted
      Last Post: 14th July 2010, 01:48 PM
    2. Nevo Or larger crank Pulley for GZE
      By Sprinterboy in forum Technical - Questions
      Last Post: 24th December 2008, 10:01 PM
    3. WTB: Cigarette Lighter/Adaptor 12V
      By li21 in forum Cars or Parts Wanted
      Last Post: 12th May 2008, 05:11 PM
    4. ciggy lighter not working
      By driftster in forum Technical - Questions
      Last Post: 15th April 2006, 10:49 AM
    5. How to make the steering feel lighter
      By slydar in forum Technical - Questions
      Last Post: 2nd January 2006, 02:43 PM
