Results 1 to 10 of 11
Thread: Clutch pedal adjustment
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Default Clutch pedal adjustment
    Hi all,
    Got my new clutch/fly/thrust bearing in, but i want to lower the friction point as it is right at the top atm.
    I have tried screwing the fork on the top of the clutch pedal in but it seems to be the same?
    Any tips appreciated
    car is ae71 with adm t50 bell using a smallport flywheel and clutch
    Aug 2010
    Geoff
    mt dandenong
    Is your clutch master a protex part or gen Toyota? If its supermarket you'll either have to swap the pin for a gen one or cut down the supermarket one depending on what you have
    Aug 2010
    Geoff
    mt dandenong
    "supermarket" damn auto correct
  • #4
    Taz
    Earlwood
    Quote Originally Posted by dove grey 64 View Post
    how would i be able to tell?
  • #5
    Aug 2010
    Geoff
    mt dandenong
    Good question. Does it look like the pin has a lot of adjustment or is it mixed out? Protex pins are too long
  • #6
    Aug 2010
    Geoff
    mt dandenong
    Gen ones might have aisin cast into it
  • #7
    Taz
    Earlwood
    Atm the rod is hitting the pedal and cannot be adjusted anymore, screwing it on makes pedal lower right?
  • #8
    Aug 2010
    Geoff
    mt dandenong
    Yeah that's aftermarket . Take the pin out and cut off about 5 to 10 mm off it. You can take out the pin while its in the car. There is a hexagonal press clip type thing holding it in. Pop it off with a flat head screw driver. Here is a tip, wind a nut down the thread before you cut off the excess. That way if you damage the thread while cutting just undo the nut and on its way off it should clean up the thread
  • #9
    Aug 2010
    Geoff
    mt dandenong
    from memory the factory rod/pin is 12mm shorter in length then the protex aftermarket clutch master.
    some guys have gotten away with not modifying the protex pins but the majority of people have issues with it.
    you might have to run the rod/pin through a tap to give it some more thread of adjustment.
    when i had this issue i swapped the oem rod/pin back in place of the aftermarket one.
  • #10
    Taz
    Earlwood
    so the oem rod fits in place of the aftermarket one if all goes to fail?
  • Page 1 of 2 1 2 LastLast
    1. clutch pedal/ gearbox maybe clutch plate issues
      Last Post: 28th January 2012, 12:28 PM
    2. Replies: 1
      Last Post: 19th October 2010, 04:30 PM
    3. Melb: Pedal assembly, hard clutch line and clutch master
      By stahlz_ae86 in forum Car Parts For Sale
      Last Post: 31st March 2009, 07:04 AM
    4. KE70 clutch adjustment??
      By shinny in forum Technical - Questions
      Last Post: 17th June 2007, 05:55 PM
    5. Clutch pedal adjustment
      By Skein in forum Technical - Questions
      Last Post: 8th September 2006, 11:06 AM
