Have you hooked up or blanked off the water lines to the bottom of the throttle body?
hello all i just finshed my 4age convertion im having issues my 4age idle she perfect on cold start up about 1k to 900rpm and then she warms up the bitch idles at like 1500-1700 someone have some idea what might be the issue
thanks VTAZ!
Where is your idle screw set to. Also adjust your throttle stop screw
^This.
I had to remove the cold-start/idle-up valve thingy on the bottom of my throttle body recently. This is all I did to fix it (sorry AE86DC won't let me attach the images so I've just linked them from RC):
Removed this from the throttle body:
Made this blanking plate(on the right):
Then fitted the plate and a new gasket to the bottom of the throttle body:
No more idle problems
the idle screw is screwed all the way in
i bought a new one of them and i still have the same issue see she idles low on cold but hot high i just dont get it this valve should work technically
So you have the bottom of the TB blocked off?
Or you have all water lines hooked up?
And you have adjusted idle screws? as in you got the throttle body stop, and you got the adjustment screw, its the recessed screw in the throttle body beside the TPS.
Inside the TB on the bottom right is a hole.
This is hole for your ISCV (idle speed control valve) ^ is this the part you refering to that you have purchased new
Read this
You have checked for vacuum leaks around intake and TVIS?
Do you have a oil catch can hooked up by chance
