Results 1 to 10 of 14
Thread: brake pedal gone hard/pressure on pedal
    May 2010
    Randwick
    Default brake pedal gone hard/pressure on pedal
    Hey lads, was driving home from work just now and when I was coming down the road to my house presses the break pedal but the was fairly hard upon just barely applying pressure to it and the breaks were very poor, they were working perfect to this point, any thoughts or solutions?
    Mar 2013
    andrew
    perth
    check if the vac line from the inlet manifold to the booster is still connected. follow the line from the booster to the inlet. if its connected and the line has vacuum when running. your brake booster is out.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    you have no vacuum assistance, check vacuum line from intake mani to brake booster
  • #4
    May 2010
    Randwick
    Thanks for the response lads, is that the 8-10mm line that rises vertically out Id the intake manifold just before it meets the block? Checked it this morn and all seems connected?
  • #5
    Mar 2013
    andrew
    perth
    follow the line FROM the brake booster. there is only one vac line that comes off the brake booster. make sure its connected and has vacuum when running.
  • #6
    Yep that is the line...
    Hard peddle is usually always vacuum related
  • #7
    May 2010
    Randwick
    Just checked there the hose is connected with no leaks, I disconnected the pipe at the brake master cylinder and there seems to be good suction, any suggestion, thanks for the feed back lads!
  • #8
    Michael
    Crimebrook 2749
    run the car, turn it off then pull the line off after the one way valve and see if its holding vacume
    id dear say booster shat itself
  • #9
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Sounds like ur booster has packed it in. Just feels like when u try and brake with the motor off like roll starting or something like that. My te71 one died n was the same. No vac assist.
  • #10
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    yeah, sounds like the booster might have given up....
    When you turn the engine off, can you hear any air escaping from around the booster area?
  • Page 1 of 2 1 2 LastLast
    1. loss of brake pedal after drift
      By Bozu in forum Technical - Questions
      Last Post: 16th August 2011, 11:49 PM
    2. Brake pedal to the floor
      By Adsie in forum Technical - Questions
      Last Post: 4th March 2010, 10:58 PM
    3. Soft Brake Pedal - Urgent
      By bigm in forum Technical - Questions
      Last Post: 12th June 2009, 09:37 PM
    4. Melb: Pedal assembly, hard clutch line and clutch master
      By stahlz_ae86 in forum Car Parts For Sale
      Last Post: 31st March 2009, 07:04 AM
    5. Brake/clutch pedal box
      By Blackers in forum Technical - Questions
      Last Post: 23rd August 2007, 02:14 PM
