Results 1 to 6 of 6
Thread: 4AGE BIG PORT CAM ID ?
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Default 4AGE BIG PORT CAM ID ?
    Hi guys I have a pair of 4AGE Big Port cams that I am trying to identify. I was told that they where a WADE REGRIND , but nothing identifies them as such and they do not seem to be CROW CAMS either. But I could be wrong.
    HERE IS WHAT I DO KNOW-----
    - original cam billett is not TOYOTA
    - part number on the cam gear end is (1465A )
    - only other marks on the cams is ( GB ) & ( 4 )
    - LOBES ARE approx 1MM higher
    - and duration appears to be longer
    - will not run properly on a std computer
    What I really am after is a brand name and I can find out from there.
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Moderator Sam-Q's Avatar
    Endeavour Hills
    it's not a Clive cam either, they use a 3 digit code and a letter.
    You could pay one of the places to measure them up and then tell you the specs that you need to dial them in
    Dec 2011
    Craig
    Granton
    Could be A Wade Profile. They do a 1056A profile For A 4age, So the Naming Convention Matches.
    I'd email Kevin On info@wadecams.com
  • #4
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    mine have 411A and 7-10 on both of my cams I have no clue as what they are. Can anyone here help?
    I got my head done at Envydyno (brookvale sydney) but got no report on the cams.
    after post googling more found this http://www.camtechcams.com.au/toy_4cyl_4age16V.html. could these be them
  • #5
    Endeavour Hills
    seems likely, I don't think cam companies share codes
  • #6
    Kaan
    Emerald
    Solved rang them and they said they are the ones and 7-10 for month and year.
  • Similar Threads
    1. Replies: 0
      Last Post: 24th January 2011, 04:26 PM
    2. small port and big port heads, 256 cam,16v rwd water stuff
      By dehney in forum Car Parts For Sale
      Last Post: 17th December 2009, 05:24 PM
    3. wtb : big port stock cam gear
      By evil86 in forum Cars or Parts Wanted
      Last Post: 3rd March 2009, 08:49 PM
    4. 4age big port head, 4age big port crank
      By cando1 in forum Car Parts For Sale
      Last Post: 23rd February 2009, 04:23 PM
    5. Replies: 2
      Last Post: 3rd January 2007, 08:52 AM
