JoJo, As I said when I first had a look at it, it is really hard to know what happened because we didn't have a good idea on what the thing looked like before the hit.
The reality is that from what should have been a relatively minor hit it ended up pushing the bottom of the strut in around 20+mm. If you remember that is roughly what we had to pull out of the other side to make it drive semi straight again. This is not even looking at caster and toe.
The load transfer path was sound but the damage caused by it was not. The standard configuration with the LCA and caster arm for a triangle which is pretty strong. I have a feeling that the revised design on your vehicle allowed for more movement that would be normally allowed.
But as I have said before, all speculation until you can get it on a jig and see what is straight and what is not.
Regards
Paul
