Results 1 to 6 of 6
Thread: Ke70 Not starting and not making sense!
    Feb 2013
    Olly
    Camden
    Default Ke70 Not starting and not making sense!
    Basically my keto isn't kicking over, dizzy is in the correct position, points have been set roughly, sparks cleaned, it has fuel, fuels going in the barrel.
    It was starting over the last few weeks (isn't rego'd at the moment) the starter motor is kicking over but after about a minute or two of trying to get it to fire it just clicks once then thats it everytime I turn the key.
    also a lot of times it has started in the past it makes a loud bubbling noise when it's first trying to start like it's misfiring but then once its running it''s all fine ( if that helps at all)
    HELP
    Elite rthy's Avatar
    Leo
    Tulla
    chuck petrol into the carby reservoir?
    Feb 2013
    Olly
    Camden
    Quote Originally Posted by rthy View Post
    as in the second barrel of the carby? I've tried carby cleaner in both barrels as well as pulling the choke fully out a few times
  • #4
    Elite rthy's Avatar
    Leo
    Tulla
    see that brass funnel in side the carb? get some petrol into it (not sure if the 4kc has the same thing)
    worked for me when i had problems starting a 4ac that was sitting around for 2 years
  • #5
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    sure it isnt flooding? did you pull the carby put in the last couple weeks?
  • #6
    Feb 2013
    Olly
    Camden
    it's started now, i pulled every lead off the dizzy even to the coil and just cleaned them all with some rough then fine grid sandpaper even though the cap is pretty much new and has only been use for 2km of driving she started better than ever now first time everytime so I'm not complaining
  • Similar Threads
    1. f*ck you altenator! Get a sense of humor!!!!
      By Brendan in forum Technical - Questions
      Last Post: 11th April 2009, 09:12 PM
    2. Ke70 '84 (drift Pig In The Making)
      By Jamie in forum Cars for Sale (Toyota Only)
      Last Post: 16th July 2008, 06:43 PM
    3. Ke70 not starting :S
      By boris in forum Technical - Questions
      Last Post: 8th March 2008, 10:46 PM
