chuck petrol into the carby reservoir?
Basically my keto isn't kicking over, dizzy is in the correct position, points have been set roughly, sparks cleaned, it has fuel, fuels going in the barrel.
It was starting over the last few weeks (isn't rego'd at the moment) the starter motor is kicking over but after about a minute or two of trying to get it to fire it just clicks once then thats it everytime I turn the key.
also a lot of times it has started in the past it makes a loud bubbling noise when it's first trying to start like it's misfiring but then once its running it''s all fine ( if that helps at all)
HELP
30kw club
as in the second barrel of the carby? I've tried carby cleaner in both barrels as well as pulling the choke fully out a few times
see that brass funnel in side the carb? get some petrol into it (not sure if the 4kc has the same thing)
worked for me when i had problems starting a 4ac that was sitting around for 2 years
30kw club
sure it isnt flooding? did you pull the carby put in the last couple weeks?
it's started now, i pulled every lead off the dizzy even to the coil and just cleaned them all with some rough then fine grid sandpaper even though the cap is pretty much new and has only been use for 2km of driving she started better than ever now first time everytime so I'm not complaining
