Results 1 to 9 of 9
Thread: {vic} shockworks rear dampers/shock absorbers
    Aug 2010
    Geoff
    mt dandenong
    Default {vic} shockworks rear dampers/shock absorbers
    have a pair of rear shockworks dampers, have only done maybe 7000k's, have never seen a track and have had a easy life.
    just the shocks are up for sale, i'd recommend you treat yourself to the remainder of the kit while your at it
    these are 10 stage adjustable from compliant daily spec to full track spec.
    "10 stage adjustable, 45mm monotube dampers with adjustable height."
    still look like new
    price: $600
    reason for sale? as i like to use my ride as a shockworks demo car im wanting to update my rear to have the new in boot adjusters, not because i need them but i like to be able to show off the new range
    anyways grab a bargain, full setup is 2k. buying these rears off me would make buying the remainder of the kit a bit cheaper i believe.
    shockworks will remove and check over these rear shocks.
    postage to be paid by buyer.
    PM shift rook if you want a price on the remaining kit bits
    Veteran McLEVIN's Avatar
    Nov 2010
    Just so you no its not that hard to adjust once installed either. Just jacck the car till the wheel is off the ground and you can get your fingers in there.
    MOPAR or no car!
    Aug 2010
    Geoff
    mt dandenong
    Like Chris said. I'm only updating to show people the new range at meets and shows etc.
  • #4
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I can adjust mine without jacking the car up, just need to lie on a creeper and you can get in there easily enough. Can definately vouch for the quality of the dampers too.
  • #5
    Veteran stahlz_ae86's Avatar
    Paul
    Anyone planning on buying a kit for a KE/AE pano or wagon should jump on these stat! The new type with in-boot adjustment will not suit the wagons and vans as well as these...
  • #6
    Aug 2012
    Jarrad
    east
    What would the shocks with rear springs/spring seats set someone back?
  • #7
    pm shift_rook for the price on the fronts...
  • #8
    Aug 2010
    Geoff
    mt dandenong
    Quote Originally Posted by Jrad View Post
    Like Matt said, pm shift rook for a price on rear springs and spring seats :-)
  • #9
    Aug 2010
    Geoff
    mt dandenong
    heaps of interest, no money seen yet.
    might be able to throw in postage.......maybe
  • Similar Threads
    1. KYB AGX Shock Absorbers and accessories
      By Anthony in forum Kaizen Garage
      Last Post: 15th November 2012, 08:57 AM
    2. Replies: 0
      Last Post: 23rd June 2011, 11:59 AM
    3. Shock absorbers
      By intense in forum Technical - Questions
      Last Post: 21st September 2008, 09:33 PM
    4. re valving shock absorbers
      By james86 in forum Technical - Questions
      Last Post: 5th September 2008, 06:48 PM
    5. Shock Absorbers
      By lowau in forum Technical - Questions
      Last Post: 11th April 2006, 12:34 PM
