Results 1 to 5 of 5
Thread: 4age pistons (ex groupA/rally engines)
    Jul 2010
    Daniel
    Auckland
    Howick
    New Zealand
    Default 4age pistons (ex groupA/rally engines)
    Hey guys,
    i have some 4age 16v engines and parts from old rally cars.
    I have a few pistons here, just wondering if some one can identify them?
Name:	2013-03-31 18.11.37.jpg
ID:	28540 Click image for larger version.
Name:	2013-03-31 18.11.25.jpg
ID:	28541 Click image for larger version.
Name:	2013-03-31 18.12.04.jpg
    Theyre mahle pistons,81.15mm diameter. look to be forged. 18mm pin (to suit a floating pin/rod)
Name:	2013-03-31 18.31.10.jpg
ID:	28543 Click image for larger version.
Name:	2013-03-31 18.31.34.jpg
ID:	28544Click image for larger version.
    Theyre mahle pistons also, 81.06mm diameter. forged aswell i think, 18mm pin same as above,
    Came in a TRD piston set box, labeled group A rally pistons.
    The block i got with this was a brand new ae86 3 rib block, got the box from japan it came in!
    Has a good condition Toyota Group A 40mm crank, is not a TRD item.
Name:	2013-03-31 17.12.32.jpg
    Next motor, has a TOYOTA R DOT BLOCK. 7rib, no oil squirters. Bigport head with a mint port job, 288/9mm cams, ran on carbs etc.
    Crank and rods are early bluetop, but the rods have been machined to take a 20mm press fit pin,
    The pistons are toyota pistons, oversized 0.5mm. Theyre flat top and look like they mightve had a teflon coating?
Name:	2013-03-31 18.56.20.jpg
ID:	28547 Click image for larger version.
Name:	2013-03-31 18.56.32.jpg
    Apparently running around 13:1 compression.
    Has anyone got any info on these? Also any info about the group a motors would be good.
    Thanks
    Daniel
    I think i got the layout ok.
    Dec 2011
    Craig
    Granton
    Quote Originally Posted by ae70_4age View Post
    Daniel, you haven't got much response, so I hope you don't mind me asking a related question. I also have a TOYOTA R DOT BLOCK and I was wondering what it signified. Do you know? Anyone? I believe my block is from an JDM RWD 4AGE big port.
    Craig
    Jul 2010
    Daniel
    Auckland
    Howick
    New Zealand
    Hey, nah its allgood man. What does yours say where the block numbers usually are? (like 4a, 4082345 or something like that)
    Im not too sure, i thought theyre blocks that werent factory fitted to vehicles, but were purchased from toyota as a reinforced block? being 7 rib. Im really not too sure..
  • #4
    Dec 2011
    Craig
    Granton
    Looks just like an engine number to me: 1364123
  • #5
    Jul 2010
    Daniel
    Auckland
    Howick
    New Zealand
    Ahh ok, my r dot block has no numbers on it, It just says 4A, and thats it.
  • Similar Threads
    1. 4age engines [melb]
      By hitoriko in forum Car Parts For Sale
      Last Post: 8th January 2010, 12:41 PM
    2. 16 X 7 +25 Volk Racing groupA evolution 2
      By GIX88 in forum Car Parts For Sale
      Last Post: 25th January 2008, 12:32 AM
    3. Shed clear out, 4AGE engines,
      By Raceflo in forum Car Parts For Sale
      Last Post: 27th March 2007, 07:16 PM
