Results 1 to 9 of 9
Thread: G series diff. Hand brake cables.
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Default G series diff. Hand brake cables.
    Hey everyone. I've fitted a g series diff into my ae71 panelvan. From what I worked out the diff is out of a yn57 hilux. Bolts onto the leafs with no mods needed. Diff is drum brake.
    My question is to do with the handbrake cables. I tried to fit the standard s series cables but failed beacause they bolt onto the drum backing plate differently. So I tried to shorten the hilux ones. Cut the cables and put them to the correct length. Cramped them back together using something I got from bunnings that is made for cramping cable wire together. Bolted them all up, and when I pulled the hand brake it was still loose. I can see the handbrake in the drum setup moving, but it isn't moving the drums. Could it be that the cables are not the correct shape anymore? As I had to bend the drivers side one a bit to fit in.
    What have other people done when fitting hilux diffs into there corollas? Is there a cable that fits or do I need to get a complete new cables made? Or should I just for a hydro?
    All help is appreciated.
    Mar 2013
    andrew
    perth
    i got mine made up at a brake shop, i marked out on the stock cables what needs to be kept (body mounting locations) then marked where on the stock cables needed to be changed to the g series (in my case jza70 handbrake) so all is stock cable, untill it goes threw the g series backing plate and onto the handbrake mechanism.
    loosen off the adjuster at the front lever to take measurements (where the cable loops) so when you get it back you have heaps of adjustment to tighten it up.
    do you have the g series cables ? they might need to match them up. so they can add them to the new cables to fit your car.
    Mar 2010
    Brett
    Crestmead
    Cheers man. Yeah I got the g series cables. I just cut the ends off, and crimped them in the correct position. Had a feeling it wouldn't be that simple but thought I would give it a go lol
  • #4
    Mar 2013
    andrew
    perth
    haha some times it is ! gota try to find out
    so the inside handbrake lever comes all the way up, and there is no more adjustment on the cable ? are the rear shoes adjusted as well ?
  • #5
    Mar 2010
    Brett
    Crestmead
    Yeah rip the lever up and nothing. Wouldn't no if the drums are adjusted. Just left them as they where. Probly wouldn't hurt to pull the drum assembly apart and freshen it up anyway.
    Was mainly wanting to know what other people have done when they have fitted different diffs
  • #6
    ACT
    Compton
    i have custom made cables in my panno with hilux diff,guy i bought it off said cost 250 in brake shop
  • #7
    Mar 2010
    Brett
    Crestmead
    thanks man. think that's what ill have to do
  • #8
    Senior Member pt_y2k's Avatar
    Paul
    Pull off the drums and have someone pull the the lever and see if there pulling in the drum?
  • #9
    Mar 2010
    Brett
    Crestmead
    Yeah I did that and they move but only slightly. Think ill have to pull the drum apart and freshen everything up a little bit. Wouldn't hurt to do that anyway.
  • Similar Threads
    1. adm hand brake cables complete and rear sway bar holders for diff
      By sprinterman68 in forum Cars or Parts Wanted
      Last Post: 30th November 2010, 04:40 PM
    2. Replies: 0
      Last Post: 2nd October 2008, 11:26 AM
    3. T / E / F series Hand brake Cables.
      By Matt-AE86 in forum Cars or Parts Wanted
      Last Post: 30th August 2008, 10:16 PM
    4. hand brake cables for a hilux diff
      By lewwy in forum Technical - Questions
      Last Post: 8th January 2008, 12:52 AM
