Results 1 to 9 of 9
Thread: Cracked 4age block at FWD engine mount
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Default Cracked 4age block at FWD engine mount
    Howdy partners,
    I was converting a 16v 4agze from FWD to RWD yesterday when u came across this:
    It is where the front engine mount attaches to inside the timing belt cover. The bolts were bent when i was taking it off, and i believe the car it was in previously did have a stack but was still drivable.
    Just wondering if anyone has seen this before?
    Cheers, Will.
    SuperFunHappySliders
    SR's are ghey.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    looks like either excessive force pulling on the bolt(the crash) or even the bolts bottomed out and someone was still smashing it with a rattle gun,
    Nathan
    Lilydale
    definitely due to crash, i pulled a ST 20V from the wreckers not too long ago that was in a front end crash, all looked good until timing cover was removed to find the same thing, engine bracket had yanked that whole section of block off the front of the engine.
  • #4
    Will
    Northern 'burbs
    Far out! I'll prolly pull this engine down to check out how bad the damage is!
    SR's are ghey.
  • #5
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you need a new block unless you want to do some seriously expensive repairs
  • #6
    Will
    Northern 'burbs
    Quote Originally Posted by Sam-Q View Post
    Yeh i don't want to use it, hoping to possibly use pistons though!
    SR's are ghey.
  • #7
    Nathan
    Lilydale
    The block on mine was a lot more damaged than yours seems to be,
    and everything internally was perfect in mine, so i wouldn't worry about it Will!
  • #8
    Will
    Northern 'burbs
    Oh sweet, cheers man!
    SR's are ghey.
  • #9
    Endeavour Hills
    your internals will be fine because you have a cracked area between the water galley and the outside of the engine. The way I see it is that for it to have enough force to go all the way to the bore this section in the front would of ripped right open.
  • Similar Threads
    1. WTB Complete engine mounts (from block to X-member mount) for 4A RWD
      By natesrolla in forum Cars or Parts Wanted
      Last Post: 3rd April 2013, 11:45 AM
    2. 4age Engine mount rubbers
      By pizzaeater in forum Technical - Questions
      Last Post: 8th March 2013, 06:44 PM
    3. wtb 4age engine mount t50 mount
      By evil86 in forum Cars or Parts Wanted
      Last Post: 2nd August 2011, 01:11 AM
    4. ae86 4age engine mount
      By mong in forum Cars or Parts Wanted
      Last Post: 29th May 2010, 02:46 PM
    5. 4age engine, 4age block, ecu, loom, gearbox
      By GZE KE70 in forum Car Parts For Sale
      Last Post: 5th March 2008, 10:12 AM
