Results 1 to 10 of 18
Thread: Sigma Lca's Into Ke70 Questions?? Sorry!
    Nov 2011
    dan
    qld
    goldcoast
    Default Sigma Lca's Into Ke70 Questions?? Sorry!
    hey all, i know theres threads out there about sigma ( GH ) lca's into ke70's and stuff.. but i can never find much detail..
    one thread iv seen say they fit straight in.. another says you need to re-drill the sway bar mount.. and more say about the sway bar + ball joint is tapered.
    if anyone reading this has done the conversion themself, can you please give me some info on what you did, and what needs to be done?
    also too, what does it mean by the balljoint is tapered? in what way is it?
    thanks alot!
    dan
    Paul
    Gold Coast
    You need to grind down the rubber bush a fair bit to fit. The swaybar mount will fit but it will be on the piss. re-drill if you want. Apparently the ball joint has a slightly different taper but I just jammed the toyota steering arm on and did it up tight. Never had an issue.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    The taper on the ball joints is different, and to be honest just jamming something on and crossing your fingers is a terrible idea when it comes to something that directly effects your ability to control the car. The "proper" way to do it is machine the sigma taper into your Toyota steering arms and redrill the swaybar mount hole. Much better way to go is extending the Toyota arms in my opinion.
  • #4
    Nov 2011
    dan
    qld
    goldcoast
    Would you possibly be able to do up a diagram or image of the part that needs to be modified ( the tapered part ) as I'm having trouble understanding exactly what part is the problem?
  • #5
    Mar 2013
    andrew
    perth
    there are 2 ends of a control arm, one bolts to the body, and the other bolts to the steering arm, under the strut VIA the ball joint. take the "new" sigma ball joint and steering arm to a machine shop, and say. i want "this" to fit "this".
    the sigma ball joint has a different taper to the toyota steering arm.
    i got charged about $150 i think. it was years ago.
  • #6
    Nov 2011
    dan
    qld
    goldcoast
    Would somebody with a laithe be able to do this? Sorry about the questions.. Can build an engine with my eyes shut but when it comes to steering I'm stumped
  • #7
    Veteran AJPS's Avatar
    Lonsdale
    dont use them, use corona arms or something else
  • #8
    Nov 2011
    dan
    qld
    goldcoast
    Quote Originally Posted by AJPS View Post
    And the reason behind this is??
  • #9
    Lonsdale
    its well documented
    but they are shit, they are too long
    the front is very over tracked compared to the rear
    makes it step out and twitchy, they are a bitch to fit you dont need that much camber
    not saying they cant work or you cant drive around the problem, but I wouldnt bother.
  • #10
    Veteran Robo86's Avatar
    Rob
    xt130 lyfe
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  • Page 1 of 2 1 2 LastLast
    1. ke70 steering rack and sigma lca
      By kid redonkulous in forum Technical - Questions
      Last Post: 19th September 2012, 09:57 PM
    2. Replies: 4
      Last Post: 30th March 2012, 08:23 AM
    3. Replies: 5
      Last Post: 25th March 2011, 03:08 PM
    4. Sigma LCA's
      By 4AGENT in forum Car Parts For Sale
      Last Post: 24th September 2010, 01:15 AM
    5. Replies: 0
      Last Post: 19th November 2009, 11:00 PM
