Results 1 to 4 of 4
Thread: Worked 5K with kawasaki quad throttles, 1.6l
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Default Worked 5K with kawasaki quad throttles, 1.6l
    I have unfortunately decided to sell the 5K setup in my KE70
    Specs:
    5K block which has been decked about 5mm with 5K crank and 5K head
    4AGE bluetop pistons and rods machined to suit 10.7:1 compression ratio
    Designed to run on 98 octane
    All internals balanced except for flywheel as I had made this lighter
    Kawasaki GPZ1100 quad throttle bodies with custom inlet manifold to suit
    Have the loom and Haltech fuel ecu to go with it
    Can come with downdraught Holley 180 that has been rebuilt
    290 degree Camtech cam, biggest 4k cam you can get from Camtech
    Uprated valve springs
    Clutch fan
    4-1 custom extractors
    New head gasket, fuel pump, seals, waterpump etc
    This engine was originally used by KE25 RACER in his IPRA KE25 then bought by another guy who sold it to me and I had it rebuild by LW Parry
    I believe it needs new piston rings though, which is only because I reused old rings when I put it all back together.
    $1500
    located in Sydney
    Reason for selling is that I need to buy a T series for my AE71
    This engine made 100kw when it was first built with its 3k head
    May 2012
    cupid cumperdale
    nsw
    cronulla
    does it come with a gearbox or do you have one you could sell with it?
    Taz
    Earlwood
    sorry no gearbox, a 4k will be put back into my ke70 for daily driving duties
    Taz
    Earlwood
    Still for sale, quads are Mikuni
  1. KE70 + worked 5K
    By anastasios in forum KE70 / AE71 Owners Forums
    Last Post: 21st February 2013, 03:04 PM
  2. 48mm quad throttles new
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 9th September 2010, 10:21 PM
  3. Blacktop Quad Throttles
    By bams_keto in forum Car Parts For Sale
    Last Post: 19th February 2010, 06:25 PM
  4. 20v quad throttles
    By yoshimitsu9 in forum Car Parts For Sale
    Last Post: 23rd January 2009, 07:13 PM
  5. set of quad throttles
    By Celica RA45 in forum Cars or Parts Wanted
    Last Post: 14th February 2008, 12:54 AM
