Results 1 to 10 of 14
Thread: 4AGE Bombing Plans - Reasonable?
    Jul 2010
    Joe
    Western Australia
    Lightbulb 4AGE Bombing Plans - Reasonable?
    Hey guys,
    I am planning on begining to upgrade my 4AGE in my AE86 Levin and want some advice on a proposed spec list.
    Before anyone flames me for posting a will this work thread I have done lots of reading and am just looking for the opinion of those who may know better than me / have more exerience with 4A series engines. Firstly, I am willing to lose some drivability for performance however I don't want an undrivable pig that only makes power after 6 grand. Secondly, yes I am chosing to keep the 16 Valve 4AGE instead of going for a 20V because I like the idea of keeping an era specific engine in it + the old 4A is a rad engine, just outclassed by new technology.
    Spec List
    HEAD
    - 4AGE Bigport Head (3 Angle Valve Job, resealed and smoothed ports, upgraded valve springs etc, decked to raise compression)
    - Compression raised to 10.5:1 to 11:1 or so
    - Camshafts around the low 290 degree mark
    * I have heard Smallport Heads lose their value after upgrading cams to this extent hence going the bigport head. Is this true?
    INTAKE & EXHAUST
    - 20 Valve Quad Throttle Bodies (Port matched, individual filters, retain 20 Valve TVIS)
    - TRD 4-2-1 Extractors
    MANAGEMENT
    OPTION 1
    - It is currently running an APEXI SAFC2 (Will this run the quads and cams this large properly? I have heard mixed reports)
    OPTION 2
    - Microtech LTX8 or Adaptronic or similar
    - Convert to CAS and Individual Coil Packs
    * Obviously the better option however if not 100% required I would prefer to keep the original ECU functionality and price
    FUEL SYSTEM
    - Surge Tank (Recirculated rise pump and 040 or similar pressure pump)
    - Standard Injectors (Apparently the current ones have been reconditioned)
    BOTTOM END
    STANDARD
    Am I dreaming to consider that the old 4A bottom end would handle this, obviously with a safeish tune and lack of abuse from a driver perspective?
    Are there any major items / conflicts with components that I have overlooked here?
    OUTCOME
    I would like to think that I could get a reliable 180 - 200 rwhp from this kind of setup. Is that a little far fetched without going to aftermarket pistons/rods and no bottom end balancing work etc
    Any helpful input would be appreciated.
    Cheers,
    Joe
    West
    How you gonna retain 20v tvis?
    Veteran AJPS's Avatar
    Lonsdale
    you would need better pipes unless youre getting genuine TRD pipes
    as for the HP estimate, yes,
    more like 140-150rwhp
  • #4
    Jul 2010
    Joe
    Western Australia
    LittleRedSpirit - from my understanding you can retain the 20v TVIS by installing the butterflies with the QTB's (which sit between the throttle bodies and the intake ports?) and running them off the standard ECU, or by setting them up on an AUX port on an aftermarket ECU and setup the RPM that they work at etc. Does that make sense or am I dreaming?
    AJPS - I guess I'll have to run with that for the time being, I might do the bottom end and swap the head over at a later stage... And yes there are already genuine TRD pipes on it.
    I really want to keep this thing N/A as I have never had a bombed N/A before and I feel like an AE86 should be N/A for some reason... Is there a more effective way of going about making power than what I am suggesting?
  • #5
    Veteran slide86's Avatar
    Huw
    Hills
    Dont run TVIS on an engine like this......it wont work
    290 degree cams are going to want some decent tuning, an aftermarket ecu such as adaptronic is what you want. But, you say you want this thing driveable, you will need to rev it to get the most out of cams like that.
    A "bombing plan" is what the US are currently doing with regards to the NK issue. I have NFI what you are talking about when you want to "bomb" an engine............
  • #6
    West
    If you want to make 200 hp from a 16v, you will need it to have a lot of lift and duration on the cams. It will be a pig really.
    If you want to make a bit less power but have a more useable power curve get a blacktop, drop in some tomei poncams and retain vvt. This will give you a power increase accross the whole rev range. A cammed up 16v to the point where its making that kind of power would be kind of difficult without a purpose built bottom end and a much higher rpm limit. With these small motors it gets to a point where hp potential comes down to how hard you want to rev it. You might be able to get 170hp from what you describe, but at what rpm and for how long. The formula atlantic engines have a service life in hours when making 220-240hp, and thats with 8 grand in crank, rods and pistons alone..
  • #7
    Dec 2011
    Kerry
    Warradale
  • #8
    i could write plenty of the subject...but realistically i dont have to...these blokes have done it for me...but i will say this...
    the mod list you have wont get close to 200rwhp...
  • #9
    Senior Member toyotakraze's Avatar
    Jun 2009
    Robbie
    Coorparoo
    From my experience you will make around 140rwhp at the limit of tuning and 115-125 rwhp dialing it back a little for safety. If you want a little more power and drivability maybe consider a 7a bottom end?
    Who took the jam outta your doughnut?
    You took the fucking jam outta my doughnut, Tommy. You did.
  • #10
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    A 7a bottom end would lower the point it makes max power by about 1000rpm, so you dont have to rev it as hard and it makes more torque anyway.
    The bigger displacement also makes the cam feel smaller. As in a 4a and a 7a with the same spec cam/everything else the 4a will sound and act grumpier, rev abit harder and be more peaky.
    i'd do,
    7a block, crank, good rods, smallport pistons, bigport head (3 angle valve job, springs ect), quads, the cams you want, adaptronic and lightweight fly.
    My setup is similar except for smallport head and 288 deg cams, its cranky below 3.5k and lacks abit of low end torque but easy to drive around.
    Accept you wont make 200rwhp and that a n/a corolla is quick, not fast and you'll reap the rewards of having a tuff sounding little screamer!
  • Page 1 of 2 1 2 LastLast
    1. Abrasive bead/sand blasting in melb at reasonable rates
      By bergs86 in forum Melbourne & Vic Events and Discussion
      Last Post: 13th April 2010, 12:09 AM
    2. KE70 or AE71, under $1000, reasonable body, SA
      By 20v ae71 in forum Cars or Parts Wanted
      Last Post: 23rd April 2009, 03:57 PM
    3. Phone Plans
      By The_81 in forum Offtopic Discussions
      Last Post: 1st August 2008, 09:41 PM
