Results 1 to 9 of 9
Thread: thermostat housing, inline stat replacement
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Default thermostat housing, inline stat replacement
    Hey guys
    My 4agte was running a bit hot and the thermostat was playing weird buggers becoz the water at the bottom of the radiator was cold. The guy who I got the car off said that he had hooked up the heater hoses not from the heater but from the block thru the thermostat and bypassing the heater so I renoved it and plumbed the heater thru the block. I bought an inline thermostat but now im unsure of which way to mount it into the hose. Like what direction. But im guessing its going to be toward the radiator from the water pump. Or where either. Would mounting it closer to the block be any better ??
    Thx again
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    The inline housing I got also takes any chev thermostat. So I also havent gotten a thermostat for it. Should I just get a 82 or 80 temp thermostat to match stock??
    Moderator Sam-Q's Avatar
    Endeavour Hills
    post a pic of your thermostat housing
  • #4
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    here u go sam
    http://i1300.photobucket.com/albums/...ps3dd86ce9.jpg
    http://i1300.photobucket.com/albums/...ps2cc6c6c1.jpg
    hope this helps, i wanna slap it together soon
    ps. sorry for Photobucket but i cant seem to upload using the forum service
  • #5
    Endeavour Hills
    I would suggest the long side of the thermostat on the block side. I don't know if it's better closer to the block.
  • #6
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Sam I woukd be replacing thqt whole housing with the inline housing you see in the picture also.. I have plumbed the heater thru the bkock.
  • #7
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    So no one has anything to say
  • #8
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    So does everyone think it will be oke without a bypass? ? Leaving the hoses plumbed thru the heater and going with an inline thermostat straight to the water pump. I wnt have a problem right?
  • #9
    Endeavour Hills
    you won't have to worry about that, all of my cooling system parts run without one as per many cars originally. You can put a 3mm hole in it to help bleed the air out though. Put it near the edge.
  • Similar Threads
    1. Remote thermostat housing
      By debeli70 in forum Cars or Parts Wanted
      Last Post: 30th July 2010, 03:26 AM
    2. wtb thermostat housing 4age
      By 15LIDE in forum Cars or Parts Wanted
      Last Post: 27th May 2010, 07:11 PM
    3. 4age thermostat housing
      By Go Fish in forum Cars or Parts Wanted
      Last Post: 3rd September 2009, 12:18 AM
    4. Inline thermostat
      By Daim in forum Technical - Questions
      Last Post: 21st March 2008, 08:03 AM
    5. Interior part, Thermostat Housing
      By Dish in forum Cars or Parts Wanted
      Last Post: 5th January 2008, 12:58 PM
