Results 1 to 8 of 8
Thread: Rod ends for trailing arms
    Brad
    Mentone
    Default Rod ends for trailing arms
    Hello
    What size rod ends are others using for their trailing arms? I am leaning towards 5/8 with either 5/8 or 3/4in threads? I can make the bars and spacers easily at work.
    Brad
    Ferny Grove
    3/4 is what we use, both shank and spherical bearing I.D you can use smaller ones but over engineering via bigger joints can't be a bad thing
    5/8ths is also fine, pretty sure Slydar has similar if not that exact size on his equal setup
    Brad
    Mentone
    Thanks Gilly. Thats what i thought but i was looking under a V8 Supercar before the holidays and they used 5/8 id joints. Im guessing more for the weight saving and they probably replace them more.
    Brad
    Veteran slydar's Avatar
    Dimitri
    i use 1/2" which is borderline too small probably. but only for the upper arms.
    i plan to use 5/8" for my lowers, currently i run stock lower arms.
    3/4" is possibly better in some ways. one way thats not always obvious is wear rate. ive read before a larger rod end will out last a smaller one as it disperses the force over a larger contact area.
    the spigot is also still pretty thin on a 5/8 rod end with a 12mm bore. prolly better in steel.
    if you end up doing 5/8th id be keen on getting at least 8 misalignment spacers off you if youre keen to do a few extra's.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    are the upper arms under less stress?
    Brad
    Mentone
    I would think the top arms would be under similar loads. The spacers im going to make will just be parallel, ie not have the groove for the rose joint to move into. There is almost no missalignment so regular spacers will work fine.
    I wount be able to do them for another couple of weeks ill let you know.
    Brad
    Senior Member Simon-KE70's Avatar
    Simon
    i'd like to work on the theory that both the uppers and lowers should be the same size even if they are under different stress loads... go for bigger!
    where are you guys getting your rod ends from and how much for?
    Brad
    Mentone
    I got my rod ends from http://stores.ebay.com/QS-Components
    Good prices and they are nice looking ends. Ony time will tell how good they are.
    Brad
  1. Power steering arms and RA60 Tie Rod Ends
    By stouty in forum Car Parts For Sale
    Last Post: 19th July 2010, 08:26 PM
  2. AE86 LCA's, Steering arms, tie rod ends
    By skaney in forum Car Parts For Sale
    Last Post: 6th January 2009, 05:43 PM
  3. New RA60 Tie Rod Ends, New Power Steering arms
    Last Post: 11th May 2008, 06:45 PM
  4. sigma LCAS, ae86 tie rod ends, ra40 stuts& steer arms
    By dr1ft-pig in forum Technical - Questions
    Last Post: 2nd December 2007, 12:05 AM
