Results 1 to 5 of 5
Thread: 4AC clutch kit
    Dim
    Menai
    Default 4AC clutch kit
    Hi I'm looking at replacing the clutch in my AE86 4AC sprinter and when I called around to a few auto parts stores most had different types parts listed for 4ag and 4ac sprinters.
    Is there a difference, and what should I be asking for, since some parts stores didn't even have a 4ac sprinter on record.
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    bro there is a clutch and brake shop on taren point road that have good prices and also aren't just reading shit out of a catalog. TYK-6319HD is the part number you're looking for. exedy HD I've run them in all 5 of my 4AG cars and only blew my diff once because of being a bit of a nuffie. good combo and won't put as much stress on the driveline than a button or cushion button
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have put a 4ac clutch onto a 4age before. First up you don't ask for the Sprinter anything, if you want a driveline part say it's for an AE71 corolla and make sure the catalouge says 1.6L.
    This is a hunch but I suspect the 4age clutch kits have a stronger clamping force.
    Anyway I have a Exedy HD clutch here that looks near new you can have cheap
  • #4
    What is the flywheel diameter difference between 4ac and 4age... 200mm for 4ac right?
    The exedy clutch plate between the hd and the standard is exactly the same... its the "pink" (not always) pressure plate that is different.
    The spring retainers have a bad rep on the exedys for cracking and making it difficult to select gears, but thats usually only after quite a few kms of abuse.
  • #5
    Veteran AJPS's Avatar
    Lonsdale
    I have some decend s/hand std ones
    and I have new exedy HD ones
    http://www.ajps.com.au/parts/parts_exedy.php
  • Similar Threads
    1. Clutch kit for 4age
      By AB-Ke70 in forum Technical - Questions
      Last Post: 21st June 2011, 08:35 PM
    2. Ke70 Clutch Kit
      By grape_moosha in forum Cars or Parts Wanted
      Last Post: 7th March 2008, 12:48 PM
    3. trd clutch kit
      By johl in forum Car Parts For Sale
      Last Post: 6th March 2008, 02:04 AM
    4. Clutch kit for 4agte
      By asher in forum Cars or Parts Wanted
      Last Post: 5th March 2007, 10:50 PM
