Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: 86 hks, trd , omori, d1, nardi, luisi, sparco part out
    Steve
    Tewantin
    Default 86 hks, trd , omori, d1, nardi, luisi, sparco part out
    OMORI guages full set as pictured $400
    trd yellow short stroke front inserts, shafts and seals perfect $100..sold
    hks 20v st timing belt $100
    nardi wheel 330mm $85. sold pending
    luisi wheel 310mm $80
    sparco wheel 350 mm with boss $70
    86 cluster $50
    caster point brace $60
    hatch rear side trims $50
    d1 quick release and boss $60
    sprinter tail lights good set $100 (lower set in pic)
    other set has small crack on lh trim and overspray on rh side $70
    mirrors $60
    http://s1272.photobucket.com/user/St...tml?sort=3&o=1
    http://s1272.photobucket.com/user/St...tml?sort=3&o=2
    http://s1272.photobucket.com/user/St...tml?sort=3&o=3
    http://s1272.photobucket.com/user/St...tml?sort=3&o=4
    http://s1272.photobucket.com/user/St...tml?sort=3&o=5
    http://s1272.photobucket.com/user/St...tml?state=copy
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    Pmd regarding the Nardi, castor rod brace and d1 quick release.
    ACT
    Compton
    much for the rocker covers?
  • #4
    Steve
    Tewantin
    $85
  • #5
    Veteran anastasios's Avatar
    Taz
    Earlwood
    what omori guages are they, i can see tach, oil temp, boost,
    what are the other 2?
    also is the nardi original?
  • #6
    Steve
    Tewantin
    guages are
    10000rpm tacho. oil temp;oil pressure, coolant temp, turbo boost
    http://s1272.photobucket.com/user/St...tml?sort=3&o=0
    nardi ; stamped on front with made in itay on rear with code number
  • #7
    Taz
    Earlwood
    do you have the fittings for oil pressure and coolant temp?
    would you be interested in selling those 2?
  • #8
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Can you measure how deep the Sparco wheel is? I need a wheel that sits a bit further back than my current one is all.
  • #9
    Steve
    Tewantin
    fitting included for engine temp and oil pressure
  • #10
    Steve
    Tewantin
    65 mm from outer rim of wheel to hub
  • Page 1 of 4 1 2 3 4 LastLast
    1. 86 parts trd bride freedom hks recaro sparco uras j blood t50
      Last Post: 5th July 2011, 08:16 PM
    2. Replies: 13
      Last Post: 30th November 2010, 11:14 AM
    3. [BNE] Adj. panhard bar, Omori, HKB, nardi, JDM cluster & more
      By kaibeecee in forum Car Parts For Sale
      Last Post: 3rd August 2010, 09:49 PM
    4. Replies: 9
      Last Post: 6th April 2010, 11:18 PM
    5. NARDI Classic + D1 Quick Release
      Last Post: 5th January 2009, 09:45 PM
