Pmd regarding the Nardi, castor rod brace and d1 quick release.
OMORI guages full set as pictured $400
trd yellow short stroke front inserts, shafts and seals perfect $100..sold
hks 20v st timing belt $100
nardi wheel 330mm $85. sold pending
luisi wheel 310mm $80
sparco wheel 350 mm with boss $70
86 cluster $50
caster point brace $60
hatch rear side trims $50
d1 quick release and boss $60
sprinter tail lights good set $100 (lower set in pic)
other set has small crack on lh trim and overspray on rh side $70
mirrors $60
much for the rocker covers?
$85
what omori guages are they, i can see tach, oil temp, boost,
what are the other 2?
also is the nardi original?
guages are
10000rpm tacho. oil temp;oil pressure, coolant temp, turbo boost
nardi ; stamped on front with made in itay on rear with code number
do you have the fittings for oil pressure and coolant temp?
would you be interested in selling those 2?
Can you measure how deep the Sparco wheel is? I need a wheel that sits a bit further back than my current one is all.
fitting included for engine temp and oil pressure
65 mm from outer rim of wheel to hub
