Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: Gearbox and Diff options for AE86 running a 4agte
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Default Gearbox and Diff options for AE86 running a 4agte
    Hey guys,
    Converting my 4agze to turbo and rebuild for track and wanted to hear everyones thoughts on box and gear options. Looking for only about 200rwkw was thinking a w55 and hilux diff?
    Anyone have any experience on fitting this and where to source etc in sydney and also any other alternatives
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    both are fine for 200kw 4a, depending on reatios of hilux diff you may want to look for w57/58 to compliment higher diff gear ratios
    Moderator Sam-Q's Avatar
    Endeavour Hills
  • #4
    Gone
    Joel
    Picton
    search and you will find. covered a zillion times
    Hilux is over kill, no decent LSD available.
    F series it the biggest you will need. choice of LSD is endless.
    any W box - W58 being the strongest of them all.
    You will need a bell housing to fit the W box, knight parts or the like.
  • #5
    Mar 2013
    Mirko
    Quote Originally Posted by sundee View Post
    Thanks mate. For w55 or w58 are there kits to do the conversion to the 4agze motor or is it bolt on?
    As for F series any one in particular you would suggest?
  • #6
    Gone
    Joel
    Picton
    none of the W box's will bolt to any 4a motor.
    you need a aftermarket bell housing, knight parts or i think dello do one.
    as for F diff, you have 2 options.. YR22 tarago or mx13 corona (mx13 or mk2 corona) as they are commonly refereed to, are the same track as ae86..1410 or 1430.. cant remember..
    Be prepared to pay decent money for a mx13 F diff.. if you pick one up for $1600 with LSD you doing stupidly good... i sold mine with no brakes and TRD 2 way for 2K
    Yr22 is about 60mm wider, i cant remember exactly though. a simple search will find the actual widths.
    The width will affect your wheel choice in offset, so do some sums before you buy wheels
    none of these diff's will bolt in, either will a G series hilux.. you need mounts etc from a donor toyota diff.
    if you want an LSD go F series, if you want the rear to be as light as it can be and reliable, go F series
    if you dont give a crap about the above get a G series and Weld it or get a full spool ( either way its locked full time.)
    Locked is rubbish IMO, but its all up to the driver.
  • #7
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    im currently doing a w55 in my car and im looking at keeping my t series diff with a weir diff center and axle kit that is said to handle 300-350 rwhp but they don't list how much traction so the less traction the more power
    tarago diff is the way to go if i didn't already have a t series but the g series from a hilux imo is shit (waiting for haters comments)
    niteparts is the company that make a bellhousing i just picked one up for $550 AUD delivered the box w55 w56 w57 and w58 are all the same strength gear ratios are almost all the same exept for 5th it gets taller as you go up the scale from w55-w58 a w55 has almost the same ratios as the t50 so that what i went with (some people believe the steel plate makes the box stronger its not true when a w5x box blows they strip gears they sont rip the box in half)
    depending on your flywheel you might not need to do anything but if you do you will need to get a new clutch plate i just got one for $70 AU sprung center organic and a custom tailshaft shop around for a decent price i have been quoted upto 1k for a shaft i told that #### to get fucked
    there is a site sponser on here Golberg who can help you out with tracking down everything and all the info needed to do the conversion
    mat
    the dyno pull to 300rwkw
  • #8
    Endeavour Hills
    Quote Originally Posted by Mirko View Post
    didn't read the links I posted?
  • #9
    Mar 2013
    Mirko
    Quote Originally Posted by Sam-Q View Post
    Sorry that was my bad was reading on my phone and missed them
  • #10
    Jake
    Northgate
    I got hilux diff and rear discs into my car cost me $400 with fully recoed calipers. I did all the mounts myself I chose hilux and locked diff mainly because it was the cheaper options, there are LSD's for hilux diff out there but doesn't bother me though.
  • Page 1 of 4 1 2 3 4 LastLast
    1. Gearbox options
      By DR1FTER in forum Technical - Questions
      Last Post: 16th February 2012, 07:22 AM
    2. suitable gearbox/diff upgrades for ADM sprinter running 4AGE 20V???
      By schmykel in forum Technical - Questions
      Last Post: 20th July 2010, 11:40 PM
    3. 4agte turbo options.
      By cotts13 in forum Technical - Questions
      Last Post: 29th March 2009, 12:47 AM
    4. mircrotech lt10...4agte...whats the best options
      By Dongaz in forum Technical - Questions
      Last Post: 17th August 2008, 12:16 PM
    5. EOI: 4agte Complete running gear to suit ae86
      By tipper86 in forum Car Parts For Sale
      Last Post: 28th March 2007, 01:33 PM
