Results 1 to 10 of 10
Thread: Tacho help
    Nov 2009
    Flaxton
    Default Tacho help
    Hi im running wasted spark with pig back ecu i think. My rpm comes up on the hand controller but i want my stock tacho to work can someone post up how to make my tacho stock work again for dummies.
    Cheers Matt
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    You need to make a tacho booster it think
    http://www.toymods.org.au/forums/tec...o-booster.html
    Nov 2009
    Flaxton
    Mk, is there a relay that doesn't require modification or a different way.
  • #4
    May 2010
    Adam
    St George
    Yes, read the link I posted, all is explained on the first page
  • #5
    Sep 2012
    Tristan
    Koongal
    What car? what engine? is the tacho output coming from the piggyback??
    i used a normal relay on mine and it worked fine, just have to be careful connecting them up so you don't damage your stock tacho
  • #6
    Nov 2009
    Flaxton
    Ae86 4agte, also can someone tell me which pin the rpm is on the dash and ecu please
  • #7
    May 2010
    Adam
    St George
    http://www.rollaclub.com/wiki/index....acho_Into_KE70
    Edit, My bad just saw u have a 86, not sure if its the same as ke70
  • #8
    Nov 2009
    Flaxton
    Na the plugs are different
  • #9
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Ok so if your running an aftermarket ecu then you need to change the output signal type from ur ecu. I bought a dakota digital off ebay and im just waiting for it to get here. But maybe you could jig some shit up like it.
    Check it out
    item.mobileweb.ebay.com.au/viewitem?itemId=251261197149&index=3&nav=SEARCH&ni d=04482564456
    If it doesnt work just ebay dakota digital and see the universal signal interface
  • #10
    Nov 2009
    Flaxton
    Ok cheers
  • Similar Threads
    1. no tacho
      By Faceplant456 in forum Technical - Questions
      Last Post: 19th April 2010, 08:29 PM
    2. what tacho to use?
      By mikewest in forum Technical - Questions
      Last Post: 24th July 2008, 12:48 PM
    3. original tacho???
      By R32.5 in forum Technical - Questions
      Last Post: 14th October 2007, 03:25 PM
    4. getting tacho to work
      By DRiiFT_King in forum Technical - Questions
      Last Post: 20th October 2006, 02:20 PM
    5. tacho
      By AE71_Rolla in forum Technical - Questions
      Last Post: 5th December 2005, 02:48 PM
