Results 1 to 8 of 8
Thread: 4AGE Flywheel Bolts.
    Dim
    Menai
    Default 4AGE Flywheel Bolts.
    What is the difference between the 4AGE and 4AC flywheel bolt. Beside from there being 6 bolts for the 4AC vs. 8 for the 4AGE.
    I screwed in a 4AC bolt to the 4AGE crank and that worked fine, however toyota parts has two different part numbers listed.
    Any toyota bolt Guru's know the answer?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    It shouldn't of physically fit because the 4ac bolts are meant to be of a bigger head diameter
    Dim
    Menai
    Ah my mistake, should have wrote that they "Threaded onto the 4age crank." So the head diamater is different.
  • #4
    Endeavour Hills
    yes, it's meant to be larger on the 4ac to the extent that they will not clear each other on an 8-bolt crank. Otherwise as you have found they are identical
  • #5
    Dim
    Menai
    Thanks Sam-Q
  • #6
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Sorry to hijack but where can I buy the flywheel bolts from to fit a JDM 4age
  • #7
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    * Toyota.... Some Toyota Dealers will have to order them, but you wont be waiting longer than 2 days.
    * Off another motor - 4age flywheel bolts are not TTY (torque to yield), so its fine to use them again (as long as they still look ok, no rust etc)
    * Aftermarket - eg ARP
  • #8
  • Similar Threads
    1. Flywheel bolts
      By trikzlane in forum Technical - Questions
      Last Post: 26th July 2011, 08:03 PM
    2. 4age parts, rwd waterpump setup, flywheel bolts + more
      By DearmanKE in forum Cars or Parts Wanted
      Last Post: 2nd September 2010, 10:34 PM
    3. WTB 4age flywheel bolts (NEW)
      By no fame in forum Cars or Parts Wanted
      Last Post: 9th February 2010, 09:44 PM
    4. snapped 4age flywheel bolts
      By sirsprinter in forum Technical - Questions
      Last Post: 1st February 2010, 12:20 AM
    5. WTB- Needed 4age flywheel bolts ASAP
      By Sprinter_Seth in forum Cars or Parts Wanted
      Last Post: 12th December 2007, 12:52 PM
