Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Australias highest KMS on a Toyota 86 and issues experienced..
    Default Australias highest KMS on a Toyota 86 and issues experienced..
    Thought it'd be worth asking how many kms has your 86 done...
    Highest i've seen so far is 23,4xx kms. And what issues have you encountered or what has been fixed under warranty?
    The most common problem encountered so far seams to be the shitty tyres they installed on the rear and them wearing out prematurely. As seen in this service notice.
    The check engine light issues reported in the first batches also appears to have been fixed by the ECU flash.
    Elite rthy's Avatar
    Leo
    Tulla
    Quote Originally Posted by Matt View Post
    seems pretty normal to me
    Veteran blair's Avatar
    Blair
    Sheldon
    Of course, that problem wouldnt have anything to do with the fact that its RWD...
    obvious troll is obvious...
  • #4
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    almost 11000kms. rear tyres will be worn soon as i will be drifting it on the track.
    no issues so far apart from it being so easy to be broken into......
  • #5
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Quote Originally Posted by Vance View Post
    You have been broken in to?!?
    I clocked over 14200km earlier tonight... I will do another 400 odd this weekend so I have my 15k service booked for next week.
    Only issue I have had is that the GPS keeps loosing where it is, I figure the antenna must not have been installed correctly and am getting them to check it out.
    Current Cars:
  • #6
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    i have heard reports of rough idle after 18,000 due to intake ports clogging up from the direct injection
    the dyno pull to 300rwkw
  • #7
    Senior Member Willofan's Avatar
    Jan 2011
    Caringbah
    Everyone I have spoken to has moisture build up in the taillights after a few months.
  • #8
    Dan/Rio
    Randwick
    there are little holes in the tails to let the moisture out. depending on humidity of the area you may or may not have moisture build up.
    that said if they were red and no one would notice......
    my idle intermittently has a hesitation every now and again.idling at 600rpm isnt helping that though. i figured it's an ecu fault rather than mechanical. my ecu hsnt been flashed yet but will be done at first service.
  • #9
    Mathew
    Sutho Shire
    i believe a good way to fix the direct injection issue would be to run e85 as it burns alot cleaner
  • #10
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    How would the intake ports be clogged from direct injection if the fuel is sprayed directly into the combustion chamber? I would think it would be the injectors wearing and needing a re-learn rather than a issue with build up.
  • Page 1 of 3 1 2 3 LastLast
    1. NSW : FS Toyota Crown 1984, Low KMs, 12 months rego
      By MoNsTaR in forum Cars for Sale (Toyota Only)
      Last Post: 13th May 2013, 08:32 PM
    2. AE101 '92 Toyota Levin - LOW LOW kms - Clean - 5sp - VANCOUVER
      By lchazl in forum Cars for Sale (Toyota Only)
      Last Post: 30th July 2009, 08:23 AM
    3. australias best 86
      By Touge205 in forum Offtopic Discussions
      Last Post: 16th March 2007, 12:06 AM
