ffs pics never work... its the one in my display pic
quick sale 600 no reg no roady vic
selling my pussay magnet due to i got paid out buy insurance, i received a small tap in the rear and not worth fixing according to panel shops. but its still straight and damage purely cosmetic which i will have pulled out, lights didn't crack nor was the bumper damaged was a small accident
this car can still be registered
its fairly rough on the outside ie rust and dings but mechnically its 100%
engine revs nice a strong to the 6,000rpm AND beyond, very healthy motor
4kc engine with 230kms
5 speed manual!!
welded diff on its way out can fall apart any moment...
new headgasket
new headstud bolts
new clutch cable
new fuel pump
newer cleaned petrol tank
new fuel filter
new ignition coil
new leads
new plugs
csx carby had 180kms when i installed it prob got 210 now
csx interior
csx wheels
csx dash (tacho)
ae71 drivers door (better mirror)
back yard rolled gaurds allround could use a once over.
cut front gaurds for castor
ac removed
ajps madhouse lip holes drilled in beaver panel
sale also comes with radom stuf ive had collected over the years
spare 4kc motor VGC.
spare steering rack
spare front sway bar
spare axles
spare NON welded diff WITH CROWN and BEARINGS your gona need this for rwc
quad light supports
aircon condenser x 2
note does NOT include rims you get cxs rims, or quad lights you get standard lights.. OR front lip that was stolen from me fml
bad points are rust around petrol filler cap and rear window and thats about it... im not gona fix it ill let u fix it the way u want to.
excellent on fuel 50$ fills the tanks and gives me 500kms EASY,this is with a little thrashing around
needs a wheel alignment because ive take my ae86 suspension out but its got choppies atm. with unknown shocks. pretty stiff and still slides well in the wet.
also the exhaust needs to be re-attached, its come loose along the welds close to the muffler.
GAURDS are in primer because i had really tight fitment and unfortenalty ruined my guards by hitting a bump to hard while sliding on lock.
DOOR is in primer because its a ae71 door NOT a ke door. its got the better mirror.
interior is good, dash is excellent no bubbles or what not, seats are good just drivers little worn needs steam clean.
can send pics to email or phone upon request
0411294023
thanks guys
PICS
muzzers dont know bout my kpgc10
price drop 700
guys i got my new car tnight, need this gone. 600 with all the bullshit
sold pending paymentooo
