Results 1 to 10 of 14
Thread: fixed timing ignition modual
    Apr 2013
    Jonathan
    qld
    wavellheights
    Default fixed timing ignition modual
    Hi all trying to figure out how to convert my 4age from a computer controled ignition advance to fixed ignition timing using a old skool ignition moduel. I found this,
    http://www.ae86drivingclub.com.au/bo...hl=distributor
    But my wire colors and number of wires are different. Any ideas on how I can figure out what goes were. Iv got the ignition and coil sorted its just the ones from my dizzy that I need.
    Veteran blair's Avatar
    Blair
    Sheldon
    Why?
    Doing the exact opposite of what you are doing was the best thing i ever did with my 4age...
    I still have the old bosch module in the shed with some wires hanging off, will have a quick look and post back here if i remember.
    Apr 2013
    Jonathan
    qld
    wavellheights
    Because I'm turboing soon n ill need static or tunable timing advance n I can't afford the latter at the moment.
  • #4
    Blair
    Sheldon
    How many wires do you have and what colours are they? whats the colour and shape of the plug?
    What is the model of ignition module, do you have pinouts/ins for that?
  • #5
    Apr 2013
    Jonathan
    qld
    wavellheights
    Green, red, yellow and white. Its a square plug with rounded corners. I have only the online guide I posted above. its an equivalent of a bosh module above in champion. Same pin configuration.
  • #6
    Blair
    Sheldon
    I had a look,
    and i think the post you found could literally be about my setup before it was transplanted into another car, as my setup was identical. white to pin 3, blue to pin 7. (Bigport 3 wire distributor)
    Did a bit of googling, try red and green?
  • #7
    Apr 2013
    Jonathan
    qld
    wavellheights
    Ok in that case, any idea what white and blue do on you dizzy? And is your dizzy double or single pick-up?
  • #8
    Apr 2013
    Jonathan
    qld
    wavellheights
    Better way to put it, were on the inside of the dizzy do the white n blue wires go..
  • #9
    Blair
    Sheldon
    White goes to both sensors. Blue only goes to the sensor with 4 teeth 90 deg apart.
  • #10
    Apr 2013
    Jonathan
    qld
    wavellheights
    Thanks mate ill try that when I get home.
  • Page 1 of 2 1 2 LastLast
    1. 4age, Ignition Timing
      By DearmanKE in forum Technical - Questions
      Last Post: 21st January 2012, 11:59 AM
    2. ignition timing wtf
      By timbo in forum Technical - Questions
      Last Post: 6th January 2010, 09:52 PM
    3. Optimal ignition timing for 4AGE
      By Gullie in forum Technical - Questions
      Last Post: 7th May 2008, 12:04 AM
    4. ignition timing
      By SNAP in forum Technical - Questions
      Last Post: 26th November 2007, 01:54 PM
