Results 1 to 7 of 7
Thread: W55 to 4agze and 20v or 16v flywheel
    Junior Member eli5's Avatar
    eli
    qld
    enoggera
    Default W55 to 4agze and 20v or 16v flywheel
    Hey so I've got a w55 supra gear box to go on my 4agze I have ordered the bell housing but need to know what flywheel to uses? Will a 16v or 20v flywheel fit and is that everything I need? Cheers
    Ray
    S.East Melbourne
    few topics about this but can depend what brand of bell housing adapter youve ordered?
    could be wrong but 200mm will fit, but possibly 212mm (with modifications to bellhousing) and 225mm wont fit at all?
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    Quote Originally Posted by djscheppy View Post
    pending bellhousing brand you buy
    200mm or 212 will fit and 225mm will (depending on brand)
    212mm is lightest factory available so i'd probably go with that (plus i have a blacktop 20v one for sale haha)
    Clutch you can use one to suit 4a + whatever flywheel size you choose then get it resplined but if you're buying new may as well find something that will fit straight up (there is one i can't remember right now, but give clutch place the disc size and spline you want they SHOULD be able to find it)
  • #4
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    If you bought a niteparts bell you can use stock 225mm 4agze clutch and flywheel. The clutch spline is the same.
    Or 212mm flywheel with corolla pressure plate and rn40 hilux clutch disk. It already has the correct spline in the middle so no need to modify a corolla one. (that's what I've got.)
    W55 clutch center is 21 spline 28.9mm.
  • #5
    blacktop 20v is a light flywheel and worth buying...
  • #6
    eli
    qld
    enoggera
    How much for the flywheel mate?
  • #7
    eli
    qld
    enoggera
    Cheers lads
  • Similar Threads
    1. W55 to 4AGE 16v
      By Mika in forum Technical - Questions
      Last Post: 18th June 2013, 10:12 PM
    2. Replies: 15
      Last Post: 27th July 2011, 12:34 AM
    3. Replies: 2
      Last Post: 4th April 2011, 11:25 PM
    4. 4agze, 20v throttle bodies, 16v extractors
      By rona_83 in forum Car Parts For Sale
      Last Post: 23rd March 2011, 01:55 PM
    5. w55, puck clutch and lightened flywheel (m series engine)
      By joshz18 in forum Car Parts For Sale
      Last Post: 1st June 2010, 10:51 PM
