Results 1 to 4 of 4
Thread: ae86 steering issue. delay in steering :s
    Senior Member BEAMS_86's Avatar
    Jan 2013
    Elanora
    Default ae86 steering issue. delay in steering :s
    Hi fellow ae86ers,
    I am having an issue with my steering in my hachi. Now last time i went to qr for Friday night practice I had a delay in my steering, so when I Went to initiate drift and I turned the steering wheel it would delay for a split second and then turn like normal and then once I would go to transition it would happen again.
    Now since I have really had no motivation for the past year to drive the car I have found some motivation to get back out there and need to fix the problem. I was under the car today to have a lookssie at what the problem could be, now there are a few things i have noticed that would need some attention but i am after a few more opinions on what this could be.
    Problems.
    1) I noticed that my Castor rod's are set nearly 20mm apart, I am not sure if this was done with the last wheel alignment for some bizzar reason, or maybe I undone them when I installed the bush kit and in a herp deep moment I forgot to allign them.
    2) steering rack needs some love, Perhaps a rebuild is in need.
    3) spring rate in the springs is stupid stiff, Going to replace as the a crazy.
    Any help would be very much appreciated as I need to sort it out so I can skid once again.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I would say it's more likely to be rack ends, tie rod ends or balljoints being worn out. Possibly the rack also, a poor alignment or stiff springs wouldn't cause a delay.
    Jan 2013
    Elanora
    1 rack end I noticed was a bit sloppy but everything else is brand new. Rack bushes are old but not broken, will replace them anyway.
  • #4
    Jack it up and check for play by shaking the wheel from 3 o'clock to 9 o'clock... It'll be worse on one side than the other.
  • Similar Threads
    1. Replies: 2
      Last Post: 3rd September 2012, 11:04 AM
    2. Replies: 1
      Last Post: 3rd July 2012, 05:33 PM
    3. steering issue
      By pogi in forum Technical - Questions
      Last Post: 30th July 2010, 11:07 AM
    4. For Sale. ae86 steering rack, steering arms, s series axles
      Last Post: 10th December 2007, 08:59 PM
    5. AE86 steering issue
      By Vezza in forum Technical - Questions
      Last Post: 30th July 2007, 11:35 AM
    Tags for this Thread
