Results 1 to 10 of 12
Thread: rwd alternator bracket install
    May 2011
    Nick
    Buderim
    Default rwd alternator bracket install
    hey guys trying to install my alternator bracket only there is a sensor of some sort in the way has anyone run into this before if so ways around it
    thanks
    wont let me upload a photo of the sensor its a round ish looking one
    May 2011
    Nick
    Buderim
    ok i know what it is now its the oil pressure sender. so is there something i need to do to it in order for me to be able to put the rwd alternator bracket
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    Quote Originally Posted by Fallen Angel View Post
    Might I ask you what car, what engine and upload a picture of the problem please?
  • #4
    Veteran Rice86's Avatar
    Richard
    Liverpool
    oil pressure sensor? the RWD (JDM) alternator bracket is designed for the throttle body side not exhaust side.
    need pictures cause we might be talking about 2 different things
    dose
  • #5
    May 2011
    Nick
    Buderim
    all good guys worked it out ifs of a 4age smallport and it is the oil pressure sensor i have been told only way around it is block the hole up and relocate the sensor with a sandwich bracket so all good i will sort it out tomorrow thanks
  • #6
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Youve got the wrong part....
    RWD bracket are on the other side of the motor..... INTAKE side
    The oil pressure sensor is on the EXHAUST side....
  • #7
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    Quote Originally Posted by maxhag View Post
    What Max said, RWD alternator sits on intake side, the Oil pressure sensor is on the intake side, in front of/below exhaust pipe for cyl #1.
    Are you talking about the knock sensor?
    Are you sure you`re fitting the alternator bracket to the right place?
    Please share a picture with us, I for one am really curious here..
  • #8
    May 2011
    Nick
    Buderim
    well my wiring for my alternator is coming out on the exhaust side (could just be how the guy that did the conversion before i got it off him did it) did have an alternator on the car but due to it being the wrong alternator he custom made a bracket that sat on that side hence why i got a new bracket and another alternator. now a mate of mine told me he ran the alternator on this side with the rwd bracket but just relocated the sensor... so thats what i was looking into
    i did have a look on the intake side but the bracket does not look like it will fit so i will give it another go tomorrow and will let u all know how i go if not then i am going to go down the path of just relocating the sensor
    have tryed to post pics up numerous times but its not letting me so i will try again tomorrow and Tore i am pretty sure its the oil pressure sensor as its located right next to the oil filter but i could be wrong
  • #9
    JoJo
    ACT
    Tuggeranong
    1. post up pics
    2. You may have a GZE bracket
  • #10
    JoJo
    ACT
    Tuggeranong
    This is a RWD alt bracket....... Mounts to the intake side.....
    Notice, there are NO sensors in that area.....
    This is the GZE bracket (notice its right near where you are mentioning the oil pressure sensor etc)
    This link may be of some use to you - http://www.ae86drivingclub.com.au/fo...ator-Solutions
    And, lastly this....... -
  • Page 1 of 2 1 2 LastLast
    1. RWD 4age alternator bracket
      By Fallen Angel in forum Cars or Parts Wanted
      Last Post: 13th April 2013, 03:37 PM
    2. WANTED: 4age Rwd Water Pump Pully And Rwd Alternator Bracket
      By BIGPORT71 in forum Cars or Parts Wanted
      Last Post: 26th May 2010, 10:11 AM
    3. RWD alternator bracket
      By JDM-086 in forum Technical - Questions
      Last Post: 9th November 2007, 08:44 PM
    4. RWD Alternator bracket
      By gottago in forum Cars or Parts Wanted
      Last Post: 27th September 2007, 03:32 PM
    5. Rwd Alternator Bracket(s)
      By TUF 086 in forum Car Parts For Sale
      Last Post: 30th June 2007, 08:27 PM
