Results 1 to 4 of 4
Thread: 4age Race Engine
    Apr 2013
    Brett
    Sefton
    Default 4age Race Engine
    4age 1760 stroker.
    16v head with port work , new valve springs, shim under bucket conversion and big Tighe Cams (899C) Duration 310, Lift 11.3mm.
    JE single ring pistons, engine has 12.2:1 compression.
    ACL full groove main bearings and race series rod bearings.
    new lower timing gear and key. new belt, adjustable cam gears
    Custom set of 44mm quad throttle bodies.
    Exedy super single LW flywheel and clutch.
    This engine has just been freshened up (this week), new bearings , valve springs and gaskets. pistons and rings are near new. The oil system has been reconfigered to the OEM internal pump,it was dry sumped, (there is no sump fitted ). All this work has been carried out by me, a qualified mechanic.
    The story behind the engine is, I brought it for the dry sump system ( which is how in my car on a std 4age) I have owned it for nearly two years ( and have not used it), I was going install it in my clubby, which would not be a problem if it was only a race car, but it is road registered, and the "better haft" does drive it from time to time, so the engine up grade that I will peruse is a std blacktop or 3sge, more drivability.
    I have been lead to believe that the engine made 220hp, and had seen very little use ( spare engine) before I purchased it.
    I am willing to part it out at the right price, e.g. Head and injection or bottom end,
    $2000 the lot ono
    Brett. w 029644 4575
    I can email pictures to interested parties.
    Nov 2009
    Flaxton
    pm sent.
    Apr 2013
    Brett
    Sefton
    This is not a street car friendly engine, approximate power range 5k to 8+, there will be not alot of torque down low, and not enough vaccum produced to operate the vaccum assisted brakes on a street car. expected idle speed will be about 1500rpm.
    the reason so cheap, it is a very small window of people that will use this type of engine spec, but it is cheap enough to buy for parts you may need for your project (price out a under shim bucket kit or stroker crank) and sell the rest, or change the cams to something more usable ( which I still may do )
  • #4
    Apr 2013
    Brett
    Sefton
    Sold pending full Payment
  • Similar Threads
    1. 4AG engine & race cams
      By terryo in forum Car Parts For Sale
      Last Post: 9th September 2009, 09:47 PM
    2. 4ag Race engine and injectors
      By ae86trueno in forum Car Parts For Sale
      Last Post: 7th July 2009, 10:35 PM
    3. 4age 20v Race Engine and Motec ECU
      By ke25 race in forum Car Parts For Sale
      Last Post: 6th February 2009, 07:43 PM
    4. RWD 4age Silvertop 20v Race Engine + W58
      By ke25 racer in forum Car Parts For Sale
      Last Post: 12th August 2008, 08:28 AM
    5. 3sge race engine
      By Clemo55 in forum Car Parts For Sale
      Last Post: 20th February 2008, 09:04 PM
