Results 1 to 4 of 4
Thread: 20v Silvertop airflow meter question
    Member Powerbite's Avatar
    Nov 2011
    Tasmania
    Launceston
    Default 20v Silvertop airflow meter question
    Alright so iv been wondering (because I can't seem to find any information on it) about the stock 20v airflow meter.
    Basically I have a AE86 with a Silvertop in it, previous owner somewhere down the track had put it in and had cut a hole in the firewall for the dizzy. Long story short ill be running the stock computer still with a dizzy relocation kit and I was wondering if there is anyway you can still run it without the airflow meter? Either trumpets or just a box to a filter. I know the blacktops you can run trumpets on the stock computer but I don't think they come with an airflow meter?
    Any info is appreciated, cheers
    The blacktop loom / ecu will run the silvertop well and is map sensored hence being able to run open trumpets... Other than that an after market ecu can be ran.
    Nov 2011
    Tasmania
    Launceston
    Quote Originally Posted by Matt View Post
    Trying to stay away from aftermarket ECUs, driven 2 silvertops '86s one with aftermarket and one with stock and the stock one apart from the rev limit was heaps better.
    Blacktop ECU/loom is a direct plugin or does it need to be modified?
  • #4
    Interesting you think that about the aftermarket ecus... The dozen or so i've driven are heaps better with the aftermarket ecu. All in the tune I guess.
    The blacktop connectors are the same as far as the engine goes, different at the ecu and you'll have to "re-wire to suit" the ae86.
  • Similar Threads
    1. Standard silvertop 20v airflow meter
      By PT86 in forum Cars or Parts Wanted
      Last Post: 15th April 2010, 06:14 PM
    2. 20v Airflow meter
      By quadeyquade in forum Cars or Parts Wanted
      Last Post: 14th April 2009, 12:05 AM
    3. 20v Silvertop N/A question
      By 20vnic in forum Technical - Questions
      Last Post: 15th August 2008, 04:44 PM
    4. coil & igniter, JDM T50, airflow meter
      By loc33e in forum Cars or Parts Wanted
      Last Post: 17th June 2008, 10:14 PM
    5. HKS boost controller, turbo timer, airflow meter adjusters
      By Rich_86 in forum Car Parts For Sale
      Last Post: 16th May 2008, 01:38 AM
