Results 1 to 4 of 4
Thread: How is the horn mechanism meant to work? Is there a fuse somewhere?
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Default How is the horn mechanism meant to work? Is there a fuse somewhere?
    So I'm perplexed, on the old steering boss the horn button was fucked so I purchased a new one. However the little contact-y thing pictured here does not reach the boss.
    Also is there a way to test if the horn works/is there a fuse, because I cant get it to work lol.
    Veteran timbo's Avatar
    Tim?
    Wild West
    It could just be stuck in that position, get some lubricating spray and see if you can wiggle it out. I had the same thing happen to me, it was just full of gunk and dust.
    Sep 2012
    Tristan
    Koongal
    same problem with mine, used electrical spray lube
    yeah once you sort out the contact, i think there is a fuse from memory...almost certain there is. Remove the plug from the horn and with a test light / multimeter check your getting 12v at one terminal and good earth at the other. 86 horns are veryy basic
  • #4
    Sep 2011
    Joey
    Queensland
    North Brisbane
    In the end, it improved with some inox, but still too short.. so I did this
    The old broken parts from the other boss + epoxy and I extended the boss's contact 1cm. Might've been a issue with the steering column idk, it has a fair bit of play.
  • Similar Threads
    1. Parts that were meant to go into my wagon - buyBuyBUY!
      By starni_boy in forum Car Parts For Sale
      Last Post: 15th February 2012, 10:14 PM
    2. KE70 drivers window reg/mechanism
      By pt_y2k in forum Cars or Parts Wanted
      Last Post: 15th February 2012, 08:33 AM
    3. light mechanism adelaide.
      By bennyq in forum Cars or Parts Wanted
      Last Post: 7th February 2011, 01:40 PM
    4. SA: AE86 Handbrake Mechanism, CA18 Radiator
      By Joel-AE86 in forum Car Parts For Sale
      Last Post: 2nd January 2008, 05:11 PM
    5. WINDOW MECHANISM man/elec
      By Touge205 in forum Cars or Parts Wanted
      Last Post: 1st May 2007, 12:28 AM
