Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: 86 won't kick over
    May 2011
    Nick
    Buderim
    Default 86 won't kick over
    Hey guys
    so changed my alternator to the right side of my 4age and went to start my car but won't kick over at all. So I tried to jump it with another car but won't still won't kick, fuel pump won't prime ether but I do have lights.... Anyone have any ideas starter motor maybe ??? Any ideas
    thanks
    Check your earths...
    May 2011
    Nick
    Buderim
    Earths seem fine but I will check them again tomorrow
  • #4
    Veteran slide86's Avatar
    Huw
    Hills
    does it crank?
  • #5
    May 2011
    Nick
    Buderim
    Narr nothing at all
  • #6
    Huw
    Hills
    I agree with Matt, sounds like there is an earth problem.
    Check the main fuses on the +ve battery terminal (if you have this setup).
  • #7
    May 2011
    Nick
    Buderim
    It was a 4ac converted to a 4age so yer I will check earths tomorrow problem with that is it started before I changed the alternator to te proper side. Alternator was orignally on the extractor side with a custom bracket all I have done since it ran is extend the alternator wires to the intake side where the alternator sits now so I am not sure so not sure about earths as I haven't touched any since it ran??
  • #8
    Huw
    Hills
    Are you sure you didnt earth out any of the alternator wiring when you extended the loom? Shorting any of these wires would have blown fuses.
    Unless of course you disconnected the battery before you started working on it.
  • #9
    May 2011
    Nick
    Buderim
    Yer battery was not connected when I did it checked all the fuses there all fine so not sure ay
  • #10
    Put a jumper cable from the batt to the starter casing or even lift hook on the motor As a quick test
  • Page 1 of 3 1 2 3 LastLast
    1. 4age in ADM 86 won't start. Wiring?
      By genkin in forum Technical - Questions
      Last Post: 31st December 2012, 09:27 AM
    2. Awards Won By The Toyota 86
      Last Post: 18th December 2012, 08:24 PM
    3. the clutch kick caboose...
      By worked in forum AE86 Owners Forums
      Last Post: 20th February 2011, 03:07 AM
    4. Cant get car to kick over.
      By DAMO46 in forum Technical - Questions
      Last Post: 30th November 2009, 11:23 PM
    5. monkey ball kick
      By breno in forum Offtopic Discussions
      Last Post: 26th July 2009, 02:53 PM
