Results 1 to 4 of 4
Thread: 83 corona help
    Apr 2013
    Vic
    Kings park
    Default 83 corona help
    Need some help with my corona could someone please tell me if I can bolt s13 front coilovers straight in ? Or what else I could use
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    S13 camber tops fit directly into ST141.
    You can use 86 camber tops however you will need to drill one hole to get them to fit.
    If you intend on going S13 front end maybe use R31 LCA's to regain some balance in front/rear track.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    What model Corona is it? (Dont say 1983, ie; model code etc......
    Is it a XT130? (Starfire engine)
  • #4
    Veteran Konakid's Avatar
    Henry
    Eastern
    S13 camber tops will need a few mm filed out of two of the holes
  • Similar Threads
    1. will a xt133 corona pedal box fit into st141 corona
      By No Offence in forum Technical - Questions
      Last Post: 6th April 2012, 07:14 PM
    2. Parts to Suit XT135 Corona, 83' model
      By MNorton in forum Cars or Parts Wanted
      Last Post: 28th May 2010, 08:52 AM
