Looks the goods man, will be sweet to see out at barbs
well my blue ke has been sitting for ages after getting stickered n stripping it to build my 86. i came across a mate selling his stickered sr ke for cheap so thought stuff it n bought it.
was a really crap build and essentially just a ke with an s14 sr tech screwed in. nearly standard everything apart from an F series. in his defense he didnt build it haha
plans were to take the diff out and sell the car on but it was in poor condition and i couldnt bare to sell something so rough.
its been sitting in my front yard for 2 months but ive been off work with a broken collar bone so figured id just mash the two together. albeit a bit better built and some better parts
plans are to build a cheap drift thrasher that i have no real attachment to with parts i have laying around. seems to be working
engine:
s14 sr20
tomei rocker stoppers
greddy sump
polyurethane mounts
fmic, new joiners
worley alu radiator
greddy remote oil filter with braided lines
generic oil cooler
full s14 wiring loom, fuse box etc
standard ecu
boost T
Driveline:
sr20 gearbox
polyurethane mount
exedy hd clutch
custom 1 piece tailshaft
E series poo
redneck lsd
Fuel:
te71 jdm efi tank
2L surge tank in boot
bosch VL main
rattler lift
new hoses
te71 8mm feed line to engine bay
susp:
new poly bushes everywhere
+40mm rose jointed lcas
ajps 40mm rcas
tein coilovers unknown rates very stiff
trd yellows front
bilstein rear
rear low springs unknown rates very stiff
cusco cambertops
ajps lock spacer
jdi knuckles
jdm brakes
rda slotted + dimpled rotors
interior:
s14 dash
oil + boost gauges
under dash components removed (heater,blower etc)
s14 loom spliced into ke loom
ta63 carina passenger seat
sparco sprint fixed back bucket
new omp harnesses
hydro handbrake
body:
front on rear conversion
hand flared fronts
madhouse lip
quad lights
front gaurds cut for castor clearance
ultra racing strut brace
ultra fender braces
15x8 +0 rota grid front
15x9 +0 rota rkr rear X6
thats about it really.
what it used to look like
donor
last few days have just been spent stripping the engine and other parts out
i also forgot that you should drain the gearbox oil before removal. lucky its my house
engine out
dash and wiring done
radiator mounted, fmic mounted, front end mock install. it all fits
so thats about where im at. i have to roll the shell up the driveway where i can take the crossmember and diff out before it can be sent to scrap.
waiting on new poly engine and gb mounts before i can fit it properly
hope yas like it
craig
yea pretty keen to get it finished real soon. back to work in 2 weeks so thats the rough deadline pending parts arrivals. hows ur ke goin? u did the 3rz yeah?
I'm surprised I've never seen your 86 around Perth mate! Not like you can miss it! Love the colour! The SR KE is looking rad! Keen to see it rip at barbs!
Haha yea I live in the hills n I'm a bit of a hermit. Plus I always stress about taking it down the hill cause of defect. It's sees the occasional trip to innaloo to see the girly but Haha. I missed the last 86 meet cause i was at work. N yea lookin forward to getting the ke finished. Should be a bit of fun at barbs.
Crossmember and front susp out of the donor today. Did a lil more on the fuel system too.
i also managed to get a sparco sprint seat, dish steering wheel with boss and a set of teins with trd shocks in them. Should be good
well it appears i have an E series not an F series like i first thought. rippin
got a bit of crap done today
the motor and box are in and bolted up and mostly wired in. steering rack has been refurbed with new boots, ends and a lock spacer. te71 fuel tank and surge tank nearly finished
have also had a few goodies arrive which is always fun
a pair of teins with camber tops and trd yellows. unsure of the spring rates but they feel pretty damn stiff ( maybe too stiff)
full front bush kit
sparco sprint fixed back with new omp 4 pt harnesses
ive got some xt130 lcas coming plus rda slotted and dimpled front rotors to suit jdm brakes
its slowly coming together
cheer
craig
Hahaha awesome, upside down photo, poxy photo bucket
well i got made redundant at work so 6 weeks paid time off
been just working on this everyday getting things sorted
interiors pretty much done, just gotta make the cover to go over the hole i had to cut for the shifter location. how do most ppl do this because its going to need to be pretty complex??
seats in, mounts modified to fit harness mount lock
harnesses are in
all wiring is finished
motors in and running now
just waitinf on the lcas and some jdi knuckles to come and i can put the susp in the front
slotted disks came
new wheels bearings in the front
diff needs to go in
fuel tank bolted in properly
tailshaft to go in
front susp to go in
then
burnouts haha
heres hopefully a quick video of it running
