Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: 4age - ae111 blacktop / What caused this
    Default 4age - ae111 blacktop / What caused this
    Long story short, I lunched a b/top 20v engine the other night that had been going well and pulled strong with no rattles or noises.
    Until on the limiter it decided to do this..
    Hole in the block below the oil pressure switch / power steer bracket
    Hole in the block below the alternator.
    Yep you can see both sides.
    #1 piston has come into contact with the exhaust valves...
    Crank has a gouge in it, and the balancing weights are missing a bit of metal.
    Conrod snapped in 3 and the piston damaged pretty badly
    Oil windage tray has been gouged as well.
    That is the bearing cap from #1, distorted and massively out of shape.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Thats massive......
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Most likely cause ------ MICE !!!!!!!!!!!!!!!!
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
  • #4
    Mar 2012
    Brett
    Vic
    Morwell
    that 20v went out in style
  • #5
    West
    How high was the limiter?
  • #6
    factory 6 speed ecu / limit, 8400..
  • #7
    Moderator Sam-Q's Avatar
    Endeavour Hills
    a few different guys like on ozclubbies claim that blacktop rods really are strong and they have meat where they are needed, but this is not an isolated case here. I say their not strong enough. Hows the head look?
  • #8
    Wheel Whore JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    Ouch, you weren't kidding about the hole.
  • #9
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    ive read around the traps that blacktops can occasionally throw a rod with regular limiter fun. doesnt seem common but can happen. i set my limiter to 8000 when i read that. sorry i forget where i saw it but. at least u went out in glory haha
  • #10
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    8500 is supposed to be max rpm for balanced AE92 Kouki rods (And theyre apparently the strongest OEM 4A rods) so I sure as heck wouldnt wanna try 8300 with stock BT rods whose weakness is near notorious!
    My condolences for your loss of what looks to have been an otherwise excellent engine!
    Next time (unless you jump on the 3S/F20/SR-train) you plan on going rev-limiter get some rods that holds (OEM Silvertop, Aftermarket like Jun or something), at minimal get the internals balanced for smooth revs, or ghetto solution get a 5spd M/T or A/T ECU for lower rpm-limit and more punch.
  • Page 1 of 3 1 2 3 LastLast
    1. [VIC] ae111 BLACKTOP 4age corolla levin $5000
      By chilli in forum Cars for Sale (Toyota Only)
      Last Post: 5th November 2012, 06:29 AM
    2. VIC ae111 levin bz-r. Blacktop 4AGE 20 Valve (6 speed manual) $8000
      Last Post: 19th December 2011, 09:41 AM
    3. VIC - corolla ae111 blacktop 4age parts and more
      By chilli in forum Car Parts For Sale
      Last Post: 23rd November 2011, 04:46 PM
    4. SA: blacktop AE111 20V 4age halfcut
      By hall sales in forum Cars or Parts Wanted
      Last Post: 21st November 2011, 07:43 PM
    5. Blacktop 20V AE111 4AGE
      By 70XIN in forum Car Parts For Sale
      Last Post: 21st January 2011, 08:32 AM
