Results 1 to 10 of 17
Thread: SR20 KE70 clearance issues
    Lakes
    Default SR20 KE70 clearance issues
    Hey guys, just asking for opinions and advice..
    I have dropped my sr20 into my ke70, I couldn't manage to get the gearbox and engine in one go cause it was getting jared up against the PS rack.. so I un bolted the tranny and now just the engine is sitting in,
    I've had a look and there's some clearance issues with the tunnel.. now should I bash it out? cut the tunnel? just wondering for ideas or ways to get around it..
    I am running all ae86 front set up..
    thanks guys!
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    What mounting kit are you using?
    The way mine is setup, and just set up another setup the same, requires cutting and welding of the tunnel/firewall....... This way uses a custom mounts to mount to a std 4a crossmember to retain close to standard steering geometry...
    You may need to also drop the X member to make it easier to get the box/engine in as one..
    Lakes
    Ones I bought off 'anastaios' they looks like a home job, they came with no rubbers. The engine has no room to play so I'm gonna have to run them solid..
    what are your thoughts?
  • #4
    JoJo
    ACT
    Tuggeranong
    post photos, iam curious to what they look like
  • #5
    Lakes
    my computers shitting itself =\ every time i go to upload the image its coming up with a red !, it wont let me
    oh okay, did you have to cut much off the tunnel/firewall? was it a big job?
  • #6
    Lakes
    do you think im better off running a s13 front set up?
  • #7
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    if you dont plan on cutting a box out of your firewall you will need to bash the trans tunnel out with a mallet
  • #8
    Lakes
    yeah, seeing I haven't got the experience welding I think bashing it out will be the way to go..
    i just want it to fit, don't really matter on aesthetics!
  • #9
    JoJo
    ACT
    Tuggeranong
    Bashing weakens the metal....
  • #10
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    I just flogged my tunnel and can get my box/engine in as one, its a tight squeeze but manageable.
    I'd stick with 86 front setup I've heard s13 front end has bad geometry in a ke/ae . I wouldn't know personally though
  • Page 1 of 2 1 2 LastLast
    1. Electrical issues - Dash, parkers, tail lights not working in Ke70
      By Low Style in forum Technical - Questions
      Last Post: 18th April 2013, 05:51 PM
    2. KE70 Electrical Issues (Clock and interior light not working)
      By tanKE70 in forum Technical - Questions
      Last Post: 13th June 2012, 04:14 PM
    3. Sr20 Issues
      By bigm in forum Technical - Questions
      Last Post: 17th April 2010, 12:28 AM
    4. best coolant? heating issues sr20
      By irl86 in forum Technical - Questions
      Last Post: 14th March 2010, 10:16 AM
    5. final clearance of 4age/ke70/ae86 parts
      By tuff te-72 in forum Car Parts For Sale
      Last Post: 9th February 2010, 01:51 AM
